1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: channel connect timeout error
To: [email protected]
Date: Thu, 20 Oct 2016 08:01:49 -0700
You must help 'caput' (all Channel Access clients) to find the specified process variables. Channel Access uses a well defined set of environment variables to configure the method used to locate PVs on a network. One of them is $EPICS_CA_ADDR_LIST, which is used to define a comma-sprated list of IP addresses of hosts that may be running an EPICS IOC holding the PV(s) of interest. It sounds like you are running the caput CA client on the same host as the IOC, so the value "localhost" may be good enough. Before running your CA clients from a bash shell session:
export EPICS_CA_ADDR_LIST="localhost"
If the IOC and CA client are on different hosts, you would use the setting:
export EPICS_CA_ADDR_LIST="the.ioc.host.ip"
where 'the.ioc.host.ip' is in either DNS name format or dotted decimal IP address format.
This assumes that you are using the EPICS CA TCP/IP ports that were configured as defaults when EPICS base was built. Both the IOC and CA clients will default to the same, compatible ports unless modified by setting $EPICS_CA_REPEATER_PORT &/or $EPICS_CA_SERVER_PORT.
Rod Nussbaumer
TRIUMF,
Vancouver, Canada
On 10/20/2016 01:43 AM, palak shimpee wrote:
I have made a small program. CTRL-FOOO:input is a variable. When I am
compiling and running IOCs, the IOC are running. But when i am writing
*caput CTRL-FOOO:input 10* on terminal window it is showing error which is
*Channel connect timed out: 'CTRL-FOOO:input' not found*
Please can I get some solution to it
thanks in advance
channel connect timeout error palak shimpee
Prev: RE: channel connect timeout error Mark Rivers
Next: Devices supported by quadEM Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 21 Oct 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
