1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Error with RTEMS on MVME5500
To: [email protected]
Date: Fri, 28 Oct 2016 13:46:24 -0400
Another quick check of an NFS server is 'showmount -e 100.100.100.110'
to probe the running server.  Failed mount attempts should be logged (eg
/var/log/syslog or similar).
Also, the RTEMS NFS client doesn't speak NFSv4 yet.
On 10/28/2016 12:05 PM, Heinz Junkes wrote:
> Bhavna,
> on host 100.100.100.110 there must be a nfs server running.
> Please check that host for nfs.server processes:
> $ ps -ef | grep nfsd
> rtems     5536  5516  0 18:01 pts/14   00:00:00 grep --color=auto nfsd
> root     19606     2  0 Aug30 ?        00:00:00 [nfsd4]
> root     19607     2  0 Aug30 ?        00:00:00 [nfsd4_callbacks]
> root     19611     2  0 Aug30 ?        00:00:00 [nfsd]
> root     19612     2  0 Aug30 ?        00:00:00 [nfsd]
> root     19613     2  0 Aug30 ?        00:00:00 [nfsd]
> root     19614     2  0 Aug30 ?        00:00:00 [nfsd]
> root     19615     2  0 Aug30 ?        00:00:00 [nfsd]
> root     19616     2  0 Aug30 ?        00:00:00 [nfsd]
> root     19617     2  0 Aug30 ?        00:00:00 [nfsd]
> root     19618     2  0 Aug30 ?        00:00:00 [nfsd]
> and /etc/exports
> that there is an entry for /tftpboot/rt_test3 like this:
> $ more /etc/exports
> # /etc/exports: the access control list for filesystems which may be
> exported
> #to NFS clients.  See exports(5).
> /tftpboot/rt_test3       100.100.100.0/24(rw,sync,no_subtree_check)
> HTH,
> Heinz
> Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
> Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
> Faradayweg 4-6        |
> D - 14195 Berlin        | E-Mail:     [email protected]
> <mailto:[email protected]>
> On 28 October 2016 at 11:22:43, भावना नितिन मेढ़ ([email protected]
> <mailto:[email protected]>) wrote:
>> Hi,
>> I am using EPICS base 3.14.12.4 built on Centos6.5 with RTEMS version
>> 4.9.1
>> The command below works ok.
>> tftpget -c100.100.100.101 -s100.100.100.110 -g100.100.100.110
>> -d/dev/enet0-a04000000 -f/rt_test3/bin/RTEMS-mvme5500/test.boot
>> I am getting following error while trying to load EPICS IOC for RTEMS on
>> MVME5500.
>> MVME5500> go -a04000000
>> Welcome to rtems-4.9.2(PowerPC/Generic (classic FPU)/mvme5500) on
>> MVME5500-0163
>> Now BSP_mem_size = 0x1FE00000
>> rtems_configuration_get_work_space_size() = 1F4000
>> Universe II PCI-VME bridge detected at 0x82000000, IRQ 12
>> Universe Master Ports:
>> Port VME-Addr Size PCI-Adrs Mode:
>> 0: 0x20000000 0x0E000000 0x90000000 A32, D64 [MBLT], Dat, Sup
>> 1: 0x00000000 0x00FF0000 0x9F000000 A24, D64 [MBLT], Dat, Sup
>> 2: 0x00000000 0x00010000 0x9FFF0000 A16, D64, Dat, Sup
>> Universe Slave Ports:
>> 0: 0x90000000 0x1FE00000 0x00000000 A32, Pgm, Dat, Sup, Usr, PWEN, PREN
>> Overriding main IRQ line PCI info with 76
>> Registering /dev/console as minor 0 (==/dev/ttyS0)
>> ***** Initializing network *****
>> Startup.
>> Ethernet driver name wmG unit 1
>> Copyright (c) 2004,2005 S. Kate Feng <[email protected]> (RTEMS/mvme5500
>> port)
>> ***** Initializing NFS *****
>> RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See
>> LICENSE fi.
>> RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE
>> file .
>> Trying to mount 100.100.100.110:/tftpboot/rt_test3 on /tftpboot/rt_test3
>> RPCIO: server '100.100.100.110' not responding - still trying
>> Unable to contact NFS server - invalid port? (RPC: Timed out)
>> nfsMount - mount: Unknown protocol
>> rtems_bsdnet_get_ntp() Can't send: Host is down
>> ***** Starting EPICS application *****
>> Can't set initial directory(/tftpboot/rt_test3/iocBoot/ioctest/): No such
>> file y
>> Can't set initial directory():
>> fatal error, exiting
>> Printing a stack trace for your convenience :-)
>> 0x00128D84--> 0x00118204--> 0x001181D0--> 0x00003254
>> RTEMS terminated; Boot manually or turn on AUTO_BOOT.
>> I have set following variables.
>> MVME5500> gevshow
>> mot-/dev/enet1-cipa=192.168.1.99
>> mot-/dev/enet1-sipa=192.168.1.4
>> mot-/dev/enet1-gipa=192.168.1.1
>> mot-/dev/enet1-file=bootrom.bin
>> epics-script=/tftpboot/rt_test3/iocBoot/ioctest/st.cmd
>> mot-/dev/enet0-cipa=100.100.100.101
>> mot-/dev/enet0-sipa=100.100.100.110
>> mot-/dev/enet0-snma=255.255.255.0
>> mot-/dev/enet0-gipa=100.100.100.110
>> epics-nfsmount=100.100.100.110:/tftpboot/rt_test3:/tftpboot/rt_test3
>> Total Number of GE Variables =10, Bytes Utilized =395, Bytes Free =3197
>> Please suggest.
>> Regards,
>> Bhavna
Error with RTEMS on MVME5500 "भावना नितिन मेढ़"
Re: Error with RTEMS on MVME5500 Heinz Junkes
Prev: Re: Error with RTEMS on MVME5500 Heinz Junkes
Next: areaDetector and ADCore R2-5 released Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: Error with RTEMS on MVME5500 "भावना नितिन मेढ़"
ANJ, 31 Oct 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
