1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: motor6-10
To: 梁雅翔 <[email protected]>, tech-talk <[email protected]>
Date: Sun, 6 Nov 2016 13:45:33 +0000
The motor module home is on github here:
https://github.com/epics-modules/motor
If you click on "13 releases" you will see that the most recent release is R6-9, there is no 6-10 yet.
If you look at the top-level Makefile you will see that the lines to build motorExApp are commented out.  You need to uncomment those lines.  Once you do that, and if ASYN is defined in your motor/configure/RELEASE file then it should build bot WithAsyn and NoAsyn.
From: [email protected] [[email protected]] on behalf of 梁雅翔 [[email protected]]
Sent: Sunday, November 06, 2016 7:13 AM
To: tech-talk
Subject: motor6-10
Hi everyone,
   I install synapps5_8 in centos7(64) with 3.14.15.2.
   When I type the command "../../bin/linux-x86-64/" in ${synapps}/motor6_9/iocboot/iocWithAsyn , I press TAB after "../../bin/linux-x86_64",I got the choice of motorSim, XPSGathering2,XPSGatheringMani. It did not have the choice of  WithAsyn and NoAsyn.
   Why it happen? I mean that when I typed "../../bin/linux-x86_64" in motor file I could get others except WithAsyn and NoAsyn.
   And asyn module was good, I make it again , no error.
   Anoter question, What is the website of motor 6-10? I only found the motor 6-9.
Liangyaxiang
Re: motor6-10 J. Lewis Muir
motor6-10 梁雅翔
Prev: motor6-10 梁雅翔
Next: Re: EPICS Base Release-Candidate Double Feature! Matt Rippa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: motor6-10 梁雅翔
Next: Re: motor6-10 J. Lewis Muir
ANJ, 07 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
