1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Base Release-Candidate Double Feature!
Cc: EPICS tech-talk <[email protected]>
Date: Sun, 6 Nov 2016 12:38:54 -1000
Is it expected that either of the latest 3.14 or 3.15 releases should build against RTEMS 4.11 ?
Trying with 3.15.5-rc1 and RTEMS 4.11 I get the following error below. I'm using the beatnik, mvme2307 and mvme3100 bsp's.
FWIW, 3.15.5-rc1 builds fine against RTEMS 4.10.
-Matt
<snip>
make[3]: Leaving directory `/home/mrippa/work/vendor/epics/base-3.15.5-rc1/src/libCom/O.RTEMS-beatnik'
make[3]: Entering directory `/home/mrippa/work/vendor/epics/base-3.15.5-rc1/src/libCom/O.RTEMS-beatnik'
Installing generic include file /gem_sw/epics/R3.15.5-rc1/base/include/os/RTEMS/osiFileName.h
mkdir /gem_sw/epics/R3.15.5-rc1/base/include/os/RTEMS
Installing generic include file /gem_sw/epics/R3.15.5-rc1/base/include/os/RTEMS/osdSock.h
<snip>
/gem_sw/targetOS/RTEMS/rtems-4.11/bin/powerpc-rtems4.11-gcc --pipe -B/gem_sw/targetOS/RTEMS/rtems-4.11/powerpc-rtems4.11/beatnik/lib/ -specs bsp_specs -qrtems   -fa
sm   -mcpu=7400 -D__ppc_generic                     -DUNIX      -O2 -g   -Wall       -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEM
S_NETWORK_CONFIG_CLUSTER_SPACE=5120     -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
ibCom/osi/os/RTEMS -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../
src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLi
b -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/
gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom
/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCo
m/yajl -I/gem_sw/epics/R3.15.5-rc1/base/include/compiler/gcc -I/gem_sw/epics/R3.15.5-rc1/base/include/os/RTEMS -I/gem_sw/epics/R3.15.5-rc1/base/include         -c .
./../../src/libCom/osi/os/RTEMS/osdPoolStatus.c
../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c: In function 'osiSufficentSpaceInPool':
../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c:20:5: error: unknown type name 'rtems_malloc_statistics_t'
    rtems_malloc_statistics_t s;
../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c:23:5: warning: implicit declaration of function 'malloc_get_statistics' [-Wimplicit-function-declaration]
    malloc_get_statistics(&s);
../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c:24:10: error: request for member 'space_available' in something not a structure or union
    n = s.space_available - (unsigned long)(s.lifetime_allocated - s.lifetime_freed);
../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c:24:46: error: request for member 'lifetime_allocated' in something not a structure or union
../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c:24:69: error: request for member 'lifetime_freed' in something not a structure or union
make[3]: *** [osdPoolStatus.o] Error 1
make[2]: *** [install.RTEMS-beatnik] Error 2
make[2]: Leaving directory `/home/mrippa/work/vendor/epics/base-3.15.5-rc1/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/home/mrippa/work/vendor/epics/base-3.15.5-rc1/src'
make: *** [src.install] Error 2
On Mon, Oct 31, 2016 at 1:05 PM, Andrew Johnson <[email protected]> wrote:
Ralph Lange and I have today tagged and generated Release Candidate[1]
versions of two new versions of EPICS Base for testing purposes. The
final releases of these will happen in about 2 weeks time provided no
major problems are reported in that period. Please report any problems
you find with these to this tech-talk mailing list.
Base-3.14.12.6-rc1
  See http://www.aps.anl.gov/epics/base/R3-14/12.php for the download
link and Release Notes.
Base-3.15.5-rc1
  See http://www.aps.anl.gov/epics/base/R3-15/5.php for the download
link and documentation.
These releases contain bug-fixes and various minor updates, and should
be compatible with software written for previous releases. See the
published Release Notes for details. Most of these modifications were
first applied to the Base-3.14 branch and the changes merged up to the
Base-3.15 branch.
One new feature that is present in both releases is that PCAS now
supports variable length array monitor updates — thanks to Matej
Sekoranja, Bruce Hill and Ralph Lange for implementing that.
The 3.15 branch does contain a major performance improvement to the IOC
when loading large numbers of database records.
Thanks to all the EPICS Core Developers for their work on these releases.
- Andrew Johnson
[1] Today's scary word for US residents
Re: EPICS Base Release-Candidate Double Feature! Michael Davidsaver
Re: EPICS Base Release-Candidate Double Feature! Heinz Junkes
EPICS Base Release-Candidate Double Feature! Andrew Johnson
Prev: RE: motor6-10 Mark Rivers
Next: Re: EPICS Base Release-Candidate Double Feature! Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: EPICS Base Release-Candidate Double Feature! Andrew Johnson
ANJ, 07 Nov 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
