If you are using ADCore 2-5, you probably need to call start() in your
plugin's constructor.
Sinisa
On 11/8/16 6:28 AM, Jonas Nilsson wrote:
I am trying to learn how to write an areaDetector plugin. As a
starting point I have tried to use the ”NDStdArrays” plugin and simply
switched all the names in the relevant source files to something else
so as to not cause a conflict with the existing NDStdArrays plugin.
The problem is that whereas the original NDStdArrays plugin appears to
work correctly (ArrayCounter_RBV increases), my version does not
appear to do so.
I have put some simple debug messages into all the functions and
member functions in the source file and while the plugin appears to
initialize correctly, processCallbacks(NDArray *pArray) is never called.
The plugin is enabled (EnableCallbacks_RBV returns ”Enable”) and I can
see no error or warning messages when starting iocsh. Does anyone have
a good idea on what might be a common beginners problem or how to
debug the problem?
Jonas
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
Argonne National Laboratory
[email protected]
(630)252-9182
- RE: processCallbacks() never called in areaDetector plugin Mark Rivers
- processCallbacks() never called in areaDetector plugin Jonas Nilsson
<2016>
2025
<2016>
2025
