I am trying to learn how to write an areaDetector plugin. As a starting point I have tried to use the ”NDStdArrays” plugin and simply switched all the names in the relevant source files to something else so as to not cause a conflict with the existing
NDStdArrays plugin. The problem is that whereas the original NDStdArrays plugin appears to work correctly (ArrayCounter_RBV increases), my version does not appear to do so.
I have put some simple debug messages into all the functions and member functions in the source file and while the plugin appears to initialize correctly, processCallbacks(NDArray *pArray) is never called.
The plugin is enabled (EnableCallbacks_RBV returns ”Enable”) and I can see no error or warning messages when starting iocsh. Does anyone have a good idea on what might be a common beginners problem or how to debug the problem?
Jonas
- Re: processCallbacks() never called in areaDetector plugin Siniša Veseli
Vacant Position - Head of Controls & Computing - Australian Synchrotron (ANSTO) Genevieve Lobo
<2016>
<2016>
ANJ, 08 Nov 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
