1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: StreamDevice/AsynIPPort question
To: "'Michael Westfall'" <[email protected]>
Cc: "[email protected] Talk" <[email protected]>
Date: Fri, 11 Nov 2016 18:40:00 +0000
Is there a way to debug where it crashes when running on RTEMS?
Sent: Friday, November 11, 2016 12:06 PM
To: Mark Rivers
Cc: [email protected] Talk
Subject: Re: StreamDevice/AsynIPPort question
We are using an RTEMS MVME-2700 target, with Asyn-4-29-1 and  StreamDevice-2-6
I think it may actually be an RTEMS BSP problem, because today I ran the same test using a Linux soft IOC, and the IOC doesn't crash when the socket isn't available like it does when running the IOC on the VME target.
On Thu, Nov 10, 2016 at 6:34 PM, Mark Rivers <[email protected]> wrote:
I run many IOCs on Linux that use StreamDevice to devices that are often disconnected for weeks, and the IOCs don’t crash.
What version of EPICS base, StreamDevice and  asyn are you running?
From: [email protected] [mailto:[email protected]] On Behalf Of Michael Westfall
Sent: Thursday, November 10, 2016 2:31 PM
To: [email protected] Talk
Subject: StreamDevice/AsynIPPort question
We are having problems with IOC crashing when a device connected by an IP socket is unavailable.
For example, in the startup script is a line like:
drvAsynIPPortConfigure("temp", "172.16.5.218:10010")
and a StreamDevice record that uses that IP port when it calls it's protocol.
 If we unplug the ethernet cable from the device (or just power it off) the IOC crashes after a short while. No error is emitted on the console  to indicate that the connection has failed.
So, I'm wondering if there is something we need to do in setting up the AsynIPPort  or the StreamDevice protocol file in order to gracefully handle the case where the socket disappears and can't be reconnected to....
Mike Westfall
Control Systems Software Engineer
Image removed by sender.
Mike Westfall
Re: StreamDevice/AsynIPPort question Michael Westfall
RE: StreamDevice/AsynIPPort question Mark Rivers
Prev: Re: StreamDevice/AsynIPPort question Michael Westfall
Next: FLOOR function in EPICS CALC error rory.clarke
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: StreamDevice/AsynIPPort question Michael Westfall
ANJ, 17 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
