hello,
I am designing an IOC for Keithley 6485 using IOC after all steps discussed in http://www.aps.anl.gov/epics/modules/soft/asyn/R4-3/HowToDoSerial/tutorial.html ,When I run the IOC following is the output -- pxbl21-1@linux-edqv:~/programs/epics/bl21/K6485/iocBoot/iocK6485> ../../bin/linux-x86_64/K6485 st.cmd #!../../bin/linux-x86_64/K6485 ## You may have to change K6485 to something else ## everywhere it appears in this file epicsEnvSet("BL","bl21:") epicsEnvSet("P","K6485:") < envPaths epicsEnvSet("ARCH","linux-x86_64") epicsEnvSet("IOC","iocK6485") epicsEnvSet("TOP","/home/pxbl21-1/programs/epics/bl21/K6485") epicsEnvSet("K6485","/home/pxbl21-1/programs/epics/bl21/K6485") epicsEnvSet("ASYN","/home/pxbl21-1/programs/epics/modules/synApps_5_6/support/asyn-4-18") epicsEnvSet("EPICS_BASE","/home/pxbl21-1/programs/epics/base-3.14.12.5") ############################################################################## cd "/home/pxbl21-1/programs/epics/bl21/K6485" ## Register all support components #dbLoadDatabase "dbd/devK6485.dbd" dbLoadDatabase "dbd/K6485.dbd" K6485_registerRecordDeviceDriver pdbbase ############################################################################### # Set up ASYN ports # drvAsynIPPortConfigure port ipInfo priority noAutoconnect noProcessEos drvAsynSerialPortConfigure("L0","/dev/ttyUSB0",0,0,0) asynSetOption("L0", -1, "baud", "57600") asynSetOption("L0", -1, "bits", "8") asynSetOption("L0", -1, "parity", "none") asynSetOption("L0", -1, "stop", "1") asynSetOption("L0", -1, "crtscts", "N") ################################################################### asynSetTraceFile("L0",-1,"") asynSetTraceMask("L0",-1,0x09) asynSetTraceIOMask("L0",-1,0x2) ############################################################################### ## Load record instances dbLoadRecords("db/devK6485.db","BL=bl21:,P=K6485:,R=1,L=0,A=-1,NELM=1000") dbLoadRecords ("db/asynRecord.db","P=K6485:,R=asyn,PORT=L0,ADDR=-1,OMAX=0,IMAX=0") cd "/home/pxbl21-1/programs/epics/bl21/K6485/iocBoot/iocK6485" iocInit Starting iocInit ############################################################################ ## EPICS R3.14.12.5 $Date: Tue 2015-03-24 09:57:35 -0500$ ## EPICS Base built Sep 15 2016 ############################################################################ Warning -- devK6485 respond2Writes is set but has no command table entry with rspLen>0. bl21:K6485:1AutozeroRBV : init_record : record type invalid for spec'd GPIB param#11 bl21:K6485:1DisplayRBV : init_record : record type invalid for spec'd GPIB param#15 bl21:K6485:1ZeroCheckRBV : init_record : record type invalid for spec'd GPIB param#12 bl21:K6485:1ZerocorrectRBV : init_record : record type invalid for spec'd GPIB param#13 bl21:K6485:1Autozero : init_record : record type invalid for spec'd GPIB param#11 bl21:K6485:1Display : init_record : record type invalid for spec'd GPIB param#15 bl21:K6485:1RangeRBV : init_record : record type invalid for spec'd GPIB param#10 iocRun: All initialization complete ## Start any sequence programs #seq sncxxx,"user=pxbl21-1Host" epics> please have a look on highlighted lines, I am unable to understand What does they mean. I hope someone to help me to get some idea. Thanks in advance With Regards, Paramveer Jain
ANJ, 15 Nov 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
