1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Philosophy regarding use of open source libraries for EPICS
To: "Konrad, Martin" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 16 Nov 2016 17:03:10 -0800
Thanks for the suggestion, Martin!
That could work nicely for our Redhat 7 systems as we could
run debian inside docker containers for IOC and application support.
It'll also make a good argument for upgrading more systems to rh7. :0)
- Bruce
On 11/16/2016 03:59 PM, Konrad, Martin wrote:
Hi Bruce,
Relying on yum repo installation of third party packages wasn't
working as the available package versions were often way out of
date.
I guess that's the price you pay for sticking to the same RHEL version
for 10 years ;-) We are planning to upgrade our OS more frequently
(whenever a new Debian version is released).
To handle this, we created a python based system we call package
manager.    It consists of python scripts that know how to build and
install typical c/c++ unix packages from tarballs using ./configure,
make, make install, and also how to build and install python packages
using setup.py build and setup.py install.    For each package type,
there's also a dependency file to specify version specific package
dependencies, and a short python file to handle quirks of each
package type.    For an easy package the new python code is about 10
lines of boilerplate, but we've also handled builds which use qmake,
autogen, cmake, etc.    We can also customize configure arguments,
build arguments, add missing headers, customize installs etc.
If you go through all that pain you can also package your software into
RPMs. We are building Debian packages for almost everything. The nice
thing about this is that we can leverage the Debian community's big pool
of packaging/build tools. Have a look at [1] for an example of the kind
of meta data we add to turn something into a proper Debian package. [2]
is an example for the build rules that are automatically generated by
the Debian tools (we usually don't need to touch them).
The best thing about all this that the packaging effort for a lot of
common packages is shared between labs [3].
-Martin
[1] https://github.com/epicsdeb/ether-ip/blob/master/debian/control
[2] https://github.com/epicsdeb/ether-ip/blob/master/debian/rules
[3] https://github.com/epicsdeb
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
Philosophy regarding use of open source libraries for EPICS Rod Nussbaumer
Re: Philosophy regarding use of open source libraries for EPICS Konrad, Martin
Prev: Re: Philosophy regarding use of open source libraries for EPICS Konrad, Martin
Next: Re: Philosophy regarding use of open source libraries for EPICS Shen, Guobao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Philosophy regarding use of open source libraries for EPICS Benjamin Franksen
ANJ, 25 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
