1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Philosophy regarding use of open source libraries for EPICS
To: "Konrad, Martin" <[email protected]>, Bruce Hill <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 25 Nov 2016 18:28:42 +0100
On 17.11.2016 00:59, Konrad, Martin wrote:
> Hi Bruce,
>> Relying on yum repo installation of third party packages wasn't
>> working as the available package versions were often way out of
>> date.
> I guess that's the price you pay for sticking to the same RHEL version
> for 10 years ;-) We are planning to upgrade our OS more frequently
> (whenever a new Debian version is released).
>> To handle this, we created a python based system we call package
>> manager.    It consists of python scripts that know how to build and
>> install typical c/c++ unix packages from tarballs using ./configure,
>> make, make install, and also how to build and install python packages
>> using setup.py build and setup.py install.    For each package type,
>> there's also a dependency file to specify version specific package
>> dependencies, and a short python file to handle quirks of each
>> package type.    For an easy package the new python code is about 10
>> lines of boilerplate, but we've also handled builds which use qmake,
>> autogen, cmake, etc.    We can also customize configure arguments,
>> build arguments, add missing headers, customize installs etc.
> If you go through all that pain you can also package your software into
> RPMs. We are building Debian packages for almost everything. The nice
> thing about this is that we can leverage the Debian community's big pool
> of packaging/build tools. Have a look at [1] for an example of the kind
> of meta data we add to turn something into a proper Debian package. [2]
> is an example for the build rules that are automatically generated by
> the Debian tools (we usually don't need to touch them).
Or you could use NixOS (http://nixos.org/), a linux distribution with a
non-destructive package manager. The advantage here is that you can have
different /development/ versions or configurations of a package
installed, something that is not easily possible in Debian & co. You can
even set up things so that regular users can install packages (which are
nevertheless shared between users).
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
Philosophy regarding use of open source libraries for EPICS Rod Nussbaumer
Re: Philosophy regarding use of open source libraries for EPICS Konrad, Martin
Prev: Re: motor6-10 Benjamin Franksen
Next: New sequencer release 2.2.4 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Philosophy regarding use of open source libraries for EPICS Bruce Hill
Next: Re: Philosophy regarding use of open source libraries for EPICS Shen, Guobao
ANJ, 25 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
