1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MCA or LabCA on Linux-64bit
From: "Ebner Simon Gregor (PSI)" <[email protected]>
To: Giovanna Campogiani <[email protected]>
Date: Fri, 18 Nov 2016 09:52:39 +0000
Hi Giovanna
This is not directly related to your question, however it might solve your base issue to have Channel Access in Matlab.
At PSI we use and (only) support this Channel Access package for Matlab: https://github.com/channelaccess/ca_matlab
No compilation no installation … you only need a recent Matlab.
Best
Simon
> On 18 Nov 2016, at 09:48, Giovanna Campogiani <[email protected]> wrote:
> Dear colleagues,
> I am trying to make the configuration files for MCA or LabCA on a Scientific Linux 64bit machine and I am get the errors at the bottom of the email.
> While searching for an answer I learnt probably the problem is within the fact that both MCA and LabCA are for a 32 bit pc. How to make MCA and LabCA compatible for a 64 bit version of MATLAB?
> Is this the real issue or am I missing something else?
> Many thanks for your support,
> best regards,
> Giovanna
> Errors reports
> when trying to make MCA
> /local/MATLAB/R2016b/bin/mex" -v -I/opt/codac-4.1/epics/base/include -I/opt/codac-4.1/epics/base/include/os/Linux -DEPICS_DLL_NO -L/opt/codac-4.1/epics/base/lib/linux-x86_64 -ldbStaticHost -lCom -lca mca.cpp MCAError.cpp Channel.cpp -O O.linux-x86_64/mca.mexglx
> Verbose mode is on.
> when trying to make LabCA
> make -C ./configure install
> make[1]: Entering directory `/home/codac-dev/MATLAB/labca_3_5_0/configure'
> make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
> make[2]: Entering directory `/home/codac-dev/MATLAB/labca_3_5_0/configure/O.linux-x86_64'
> perl /opt/codac-4.1/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
> make[2]: Leaving directory `/home/codac-dev/MATLAB/labca_3_5_0/configure/O.linux-x86_64'
> make[1]: Leaving directory `/home/codac-dev/MATLAB/labca_3_5_0/configure'
> make -C ./ezca install
> make[1]: Entering directory `/home/codac-dev/MATLAB/labca_3_5_0/ezca'
> make[2]: Entering directory `/home/codac-dev/MATLAB/labca_3_5_0/ezca/O.linux-x86_64'
> /usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall     -g  -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../include/os/Linux -I../../include         ../ezca.c
> make[2]: Leaving directory `/home/codac-dev/MATLAB/labca_3_5_0/ezca/O.linux-x86_64'
> make[1]: Leaving directory `/home/codac-dev/MATLAB/labca_3_5_0/ezca'
> Giovanna Campogiani
> Accelerator Physics PhD Student
> Electronics Engineer
> Sapienza University of Rome
> INFN - National Institute of Nuclear Physics
> e-mail: [email protected]
Re: MCA or LabCA on Linux-64bit Giovanna Campogiani
Prev: Re: MCA or LabCA on Linux-64bit Hinxx
Next: Re: MCA or LabCA on Linux-64bit Giovanna Campogiani
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 18 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
