1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base Release-Candidate Double Feature!
To: Matt Rippa <[email protected]>
Cc: Talk EPICS Tech <[email protected]>
Date: Fri, 18 Nov 2016 11:30:35 -0600
Hi Matt,
On 11/17/2016 09:25 PM, Matt Rippa wrote:
> I can't seem to track down a change to dbGetLinkValue() which is now
> missing from R3.15.
> In R3.14.12.4 it's defined here:
> dbAccessDefs.h: epicsShareFunc long epicsShareAPI dbGetLinkValue(
>     struct link *,short dbrType,void *pbuffer,long *options,long *nRequest);
dbGetLinkValue() was meant to be an internal API; the documented API was
actually a macro called dbGetLink() with the same arguments. Section
15.4.2.2 of the Application Developers Guide says "dbGetLink is
implemented as a macro that calls dbGetLinkValue and can reference its
arguments more than once. The macro skips the call for constant links.
User code should never call dbGetLinkValue."
We have replaced the macro with a function dbGetLink() which is now
declared in dbLink.h and has the same arguments:
> epicsShareFunc long dbGetLink(struct link *, short dbrType, void *pbuffer,
>         long *options, long *nRequest);
This was part of the move to making link-types extensible which will be
coming in Base-3.16.1
HTH,
- Andrew
Linking a HIGH and LOW field to a PV Bo Jakobsen
EPICS Base Release-Candidate Double Feature! Andrew Johnson
RE: EPICS Base Release-Candidate Double Feature! freddie.akeroyd
Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
Re: EPICS Base Release-Candidate Double Feature! Johnson, Andrew N.
Re: EPICS Base Release-Candidate Double Feature! Matt Rippa
Prev: RE: MCA or LabCA on Linux-64bit Allison, Stephanie
Next: Linking a HIGH and LOW field to a PV Bo Jakobsen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS Base Release-Candidate Double Feature! Matt Rippa
ANJ, 21 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
