Thank you for your reply, which is very useful to me.
Actually there is no strict limit for non-expert staff onsite.
Yingbing
On 11/22/2016 10:15 PM, Mark Rivers wrote:
> If you use ssh or VNC then you should be able to implement the same authentication policy from offsite as the one you use onsite?
> I typically use ssh if I need to access a Linux machine from offsite, and VNC if I need to access a Windows machine.
> How do you handle non-expert staff onsite?
> Mark
> From: 阎映炳 [[email protected]]
> Sent: Tuesday, November 22, 2016 8:00 AM
> To: Mark Rivers; epics Techtalk
> Subject: Re: Control system remote access
> Dear Mark,
> I am considering the first case, which is used for the staff. But I want
> to introduce some authentication policy. Not everyone is an expert :)
> Best regards,
> Yingbing
> On 11/22/2016 09:20 PM, Mark Rivers wrote:
>> Hi Yingbing,
>> I think you need to describe the desired usage more completely.
>> Is the remote access needed for SSRF staff to diagnose and fix problems from offsite? Or is it for users to be able to conduct experiments and retrieve data remotely.
>> The first problem is much easier and we do it routinely at the APS. Tools include ssh, VNC, etc.
>> The second problem is more difficult. You need to worry about authentication, exactly what controls you can safely allow to be controlled from non-expert users remotely, etc. Some beamlines at the APS do this, particularly the protein crystallography ones.
>> Mark
>> From: [email protected] [[email protected]] on behalf of 阎映炳 [[email protected]]
>> Sent: Tuesday, November 22, 2016 1:14 AM
>> To: epics Techtalk
>> Subject: Control system remote access
>> Hi,
>> The SSRF control system is based on EPICS. It has been operated more
>> than seven years. Recently the need for remote access (outside of the
>> gateway) became more and more urgent. I want to make a survey.
>> 1. Does your control system allow remote access ? Only monitor, or ... ?
>> 2. What is the best way to implement it?
>> 3. Is it possible to browse the archive data?
>> Thank you and best regards,
>> Dr. Yingbing YAN
>> Control Group | SSRF | SXFEL
>> Shanghai Institute of Applied Physics, Chinese Academy of Sciences
>> No. 239 Zhangheng Road, Shanghai, China
- Control system remote access 阎映炳
- RE: Control system remote access Mark Rivers
- Re: Control system remote access 阎映炳
Re: Linking a HIGH and LOW field to a PV Andrew Johnson
Re: Linking a HIGH and LOW field to a PV Bo Jakobsen
<2016>
2025
Re: Control system remote access Wesley Moore
<2016>
2025
