1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Linking a HIGH and LOW field to a PV
To: [email protected]
Date: Wed, 23 Nov 2016 09:53:15 +0100
Hi
That was a nice solution, thank you.
Best
Bo
On 2016-11-22 18:21, Andrew Johnson wrote:
Hi Bo,
On 11/22/2016 02:24 AM, Bo Jakobsen wrote:
It is still unclear to me if the problem is to get the ao record to
process the value or if it is simply not possible to define the HIGH and
LOW fields as CA links.
The HIGH and LOW fields of an ao record are just doubles, you can't make
them into links like you want to.
However, what types of records are your two $(P):SUBCRYO_SETP_MIN and
$(P):SUBCRYO_SETP_MAX limit records? If these are also ao records with a
soft-channel device support whose OUT fields are not already in use then
you could just point those OUT fields (which _are_ links) to point to
the $(P):SUBCRYO_SETP_S.LOW and $(P):SUBCRYO_SETP_S.HIGH fields
respectively, which would update them automatically whenever the user
modifies the source values.
If the OUT fields are already in use I would suggest using a SEQ record
to copy the values from those two into the LOW and HIGHT fields — a
calcout record can only copy one value so you'd have to have two of
them, whereas a single SEQ record can copy many values in a single
process operation.
- Andrew
On 2016-11-21 15:12, Steiner, Mathias wrote:
The brute force approach would be to use a calcout...
record(calcout, "$(P):SUBCRYO_SET_LOW") {
   field(INPA, "$(P):SUBCRYO_SETP_MIN.VAL CP")
   field(CALC, “A”)
   field(OUT , "$(P):SUBCRYO_SETP_S.LOW PP")
..and similar for .HIGH.
It’s the opposite of elegant but it’ll work.
cheers -mathias
[mailto:[email protected]] *On Behalf Of *Bo Jakobsen
*Sent:* Monday, November 21, 2016 09:01
*To:* [email protected]
*Subject:* Linking a HIGH and LOW field to a PV
Hi
I am trying to get "limits" to work on a "Soft Channel" record.
The challenge is that I have the limit values in another record, and
want to make a link between the two records.
I would therefore like to something like this:
record(ao, "$(P):SUBCRYO_SETP_S") {
   field(DESC, "Huginn Sub-cryostat system setpoint")
   field(DTYP, "Soft Channel")
   field(VAL, "300")
   field(PREC, "3")
   field(EGU, "K")
   field(PINI, "YES")
   field(HSV, "MINOR")
   field(LSV, "MINOR")
   field(LOW, "$(P):SUBCRYO_SETP_MIN.VAL CP")
   field(HIGH, "$(P):SUBCRYO_SETP_MAX CP")
which, however, does not work.
It this possible, and in that case how.
Thanks in advance.
     Bo
EPICS Base Release-Candidate Double Feature! Andrew Johnson
RE: EPICS Base Release-Candidate Double Feature! freddie.akeroyd
Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
Re: EPICS Base Release-Candidate Double Feature! Johnson, Andrew N.
Re: EPICS Base Release-Candidate Double Feature! Matt Rippa
RE: Linking a HIGH and LOW field to a PV Steiner, Mathias
Re: Linking a HIGH and LOW field to a PV Bo Jakobsen
Re: Linking a HIGH and LOW field to a PV Andrew Johnson
Prev: Re: Control system remote access 阎映炳
Next: EPICS Archiver appliance, only the first container is launched correctly Max Power
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Linking a HIGH and LOW field to a PV Andrew Johnson
Next: RE: Linking a HIGH and LOW field to a PV Dudley, David
ANJ, 24 Nov 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
