hi, Ralph
This is information of device,
Gamma Vacuum Ion Pump with controller.
By the way, How can I get rid of the unwanted characters which are
"\377\372,j`\377\36005 OK 00 TORR B1" for getting only interested
data? I guess need to use @mismatch(exception handler) but the
things of example which is in stream manual is too weak for me.
Best Regards,
PilkyuJung
On 12/02/2016 05:52 PM, Ralph Lange
wrote:
Hi Pilkyu,
Can you tell the vendor and type of your device?
If it is a common product, there's a good chance that a
tested protocol and sample database already exist.
Otherwise, you will have to get rid of the unwanted
characters in the 'in' part of your protocol, until only the
number you're interested in gets extracted and pushed to the
record.
Cheers,
~Ralph
- RE: Capturing data from string which is sent by device Mark Rivers
- Capturing data from string which is sent by device 정필규
- Re: Capturing data from string which is sent by device Ralph Lange
RE: Running IOC without network connection Mark Rivers
<2016>
<2016>
ANJ, 04 Dec 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
