Recsync is now being maintained by Dylan Maxwell.
https://github.com/ChannelFinder/recsync
Recsync is intended to maintain a authoritative central database of all
records provided by all IOCs. In order to be authoritative, each IOC
maintains a persistent TCP connection to a central server. This gives
some feature overlap with aliveRecord*.
Zero configuration is a goal. No per-IOC config is required. Just link
in the reccaster support module. There is an optional .db which
provides connection status.
While intended to be used with channelfinder, it is not tightly coupled,
and could be used with other databases.
* In my ideal super efficient world, aliveRecord would use the recsync
protocol.
The alive daemon I maintain for my group has zero configuration as
well. Just point the alive record to the daemon, and it adds the IOC to
the database, and infrequently probes for information. All the
information for doing this is in the alive packet.
UDP packets are used because if the packets get lost, the IOC doesn't
care. There's no worrying about reconnecting if the server goes down,
as there is no persistent connection with UDP. The design of alive is
to minimize the affect of the remote server on the IOC. The only direct
connection allowed from the server is in the form of allowing a
connection on a TCP port, alive shoves its information into it, and
immediately closes it. The server can't write to the IOC or even keep a
port open.
With UDP, I have all UDP packets incoming onto the same port on the
server, and the same thread just keeps reading packets off the same
port. If the IOC information needs to be read using the TCP port on the
IOC, I just spawn a temporary thread for that purpose. There is also no
buffer allocated for UDP. With TCP, each connection get passed off to a
new port, needing a separate socket which also has its own buffer
attached to it. As we have hundreds of IOCs talking to the server, I
don't want a TCP connection.
So, alive is not switching to TCP....
Dohn
- IOC and its OS health monitoring Shen, Guobao
- Re: IOC and its OS health monitoring Shen, Guobao
- Re: IOC and its OS health monitoring Michael Davidsaver
Re: Alive record server Dohn Arms
<2016>
Acromag IP230A/231 support Ron Sluiter
<2016>
ANJ, 22 Dec 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
