1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: 答复: Question about "Link A array too large"
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>, Hugo Slepicka <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 30 Dec 2016 01:17:17 +0000
Thanks for your respond.
Yes, it is the exact error message. however, I try to solve the problem by deleting the asyn, ipac and gensub folder respectively and change another path and recompiling them again. Now, they work well.
The version of EPICS base is 3.14.12.5, ASYN is 4.9, IPAC is 2.14, gensub is 1.6 respectively.
发件人: Mark Rivers <[email protected]>
发送时间: 2016年12月29日 18:55
收件人: lzf neu
抄送: [email protected]
主题: Re: Question about "Link A array too large"
What version of EPICS base, asyn, and modbus are you using? I cannot find any error messages in base 3.14.12.5 that contain the string "array too large". Is that the exact error message you are getting? Since you are getting a core dump you can run gdb on the core file to see exactly where it is crashing.
Sent from my iPhone
> On Dec 28, 2016, at 9:15 AM, lzf neu <[email protected]> wrote:
> Hi all,
> I want to read real-time dose value from the radiation monitor by using epics. The driver is modbus and asyn.
> However,when starting epics ioc in server, I encounter a problem, the terminal displays something like the following information:
> Link A array too large..
> Link B array too large..
> Link L array too large...
> Segment fault(core dump)
> The operation system used in server is fedora20 64bit. However, the same operation system and the same modbus and asyn driver works well in my laptop connected to the monitor.
> Could you give me some suggestions to solve the problem, thanks in advanced.
Re: 答复: Question about "Link A array too large" Mark Rivers
Re: Question about "Link A array too large" Mark Rivers
Prev: Re: Question about "Link A array too large" Michael Davidsaver
Next: Re: 答复: Question about "Link A array too large" Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 29 Dec 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
