> On 01/06/2017 05:30 PM, Konrad, Martin wrote:
> > Are there any drivers that populate this dynamically on
> > IOC start from a configuration file or even from the EPICS database file?
> The aravisGigE driver lazily creates parameters in drvUserCreate().
An example of a record using this approach:
https://github.com/areaDetector/aravisGigE/blob/master/aravisGigEApp/Db/AVT_Mako_1_52.template#L78
The OUT field is parsed, and the string "ARVI_SensorBit" is then available as drvInfo in drvUserCreate():
https://github.com/areaDetector/aravisGigE/blob/master/aravisGigEApp/src/aravisCamera.cpp#L362
This string tells the driver that it is a parameter ("SensorBit") that can be looked up from the camera ("ARV"), with integer format ("I").
I never dug deeper to find out if you can get the requested DTYP of the record. If you could, then you could dispense with the format character ("I" in this case) in the OUT field.
Tom
- Asyn and devices with changing register map Konrad, Martin
- Re: Asyn and devices with changing register map Michael Davidsaver
RE: synApps_5_8 build error Abdalla Ahmad
RE: synApps_5_8 build error Mark Rivers
<2017>
2025
RE: Asyn and devices with changing register map Mark Rivers
<2017>
2025
