Hello Hugo,
I wrote the following for a related issue. 1st, some explanation.
This method was given to me by Andrew Johnson (APS) and Janet
Anderson (retired). "BCDA" (Beamlines Controls and Data
Acquisition) is my home group here at the APS. "dserve's" refers to
hard disk servers that we use to make various versions of EPICSbase
and synApps available to all our beamlines for building EPICS IOC's.
Maintaining
EPICS Build Host Backward Compatibility
In order to maintain compatibility across multiple RHEL OS
versions (e.g. RHEL6 & RHEL7) at the beamlines, BCDA must
use a workstation with the oldest OS version available when
building software (e.g. EPICS base & synApps) for
distribution on the shared dserve's. If this is not done, then
utilities that use OS shared runtime libraries (e.g.,
EPICSbase's "antelope") will be built with links to newer
versions of libraries that do not reside on workstations with
older OS versions. When workstations with the older OS run that
utility, they fail. The assumption with this method is that
newer OS versions will always be backward compatible with the
older version.
We tried doing something similar to your "possible solution"; we
created OS version specific EPICS_HOST_ARCH's; e.g.,
linux-x86_64-el5, linux-x86_64-el6. It was unwieldy and difficult
to remember which versions of synApps supported which OS versions,
so we abandoned it for the above method. It is still somewhat
complicated (see attached), but supporting a limited number of
EPICS_HOST_ARCH's helps.
Ron
On 1/9/2017 11:36 AM, Hugo Slepicka
wrote:
Hi All,
I would like some input from the community regarding the
organization of EPICS build for multiple OS targets (not
cross-compiling), e.g. RHEL (5, 6, 7), Debian and other
flavors available to coexist in a shared directory
structure.
How is the community handling cases similar to rhel7-x86_64
versus rhel6-x86_64 given that "EPICS_HOST_ARCH" returns
"linux-x86_64" for both?
One possible
solutions would be to use something like:
<shared_path>/<os_version>/base/.../<EPICS_HOST_ARCH>/...
- where
os_version would be: rhel5, rhel6, deb7, deb8, etc.
Another solution would be to apply a local patch to the
EPICS building system to return a specific value for
EPICS_HOST_ARCH including the <os_version>, e.g.
rhel6-x86_64, resulting in something like this:
<shared_path>/base/.../<NEW_EPICS_HOST_ARCH>/...
Hugo
synApps distributions.pdf
Description: Adobe PDF document
- RE: Multiple OS Build Mark Rivers
- Multiple OS Build Hugo Slepicka
Re: Multiple OS Build Ralph Lange
<2017>
<2017>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
