Subject: Re: Problem with parallel make with seq 2.2.4 on Linux
To: <[email protected]>
Date: Fri, 13 Jan 2017 11:32:32 -0600
On 01/13/2017 10:21 AM, Mark Rivers wrote:
> I am seeing frequent errors when building seq 2.2.4 on Linux with
> parallel make.  This is with base 3.15.5 on a 20-core machine.
> Sometimes it works:
> corvette:~/support/seq-2-2-4>make -sj clean.linux-x86
> corvette:~/support/seq-2-2-4>make -sj install.linux-x86
> 2 parsing conflicts.
> But often it fails:
> ../var_types.c:17:17: fatal error: snl.h: No such file or directory
> #include "snl.h"
> compilation terminated.
> Running make a second time seems to always allow the build to complete.
There's a dependency rule missing from the src/Makefile, but the rule
gets created in the var_types.d file which is included in subsequent
built attempts. Ben does have some rules in that Makefile and he's
trying to support the different dependency rules in 3.14 vs 3.15, but I
suspect GNUmake on a 20-core box is more cunning than the current rules are.
In Ben's defence it isn't easy to write Makefile rules where a single
command generates more than one file, as seems to be the case with lemon.
- Andrew
Re: Problem with parallel make with seq 2.2.4 on Linux Ben Franksen
Problem with parallel make with seq 2.2.4 on Linux Mark Rivers
Prev: Re: Problems with seq 2.2.4 on Windows Andrew Johnson
Next: StreamDevice 2.7.7 won't build with Visual Studio 2010 Mark Rivers
Prev: Problem with parallel make with seq 2.2.4 on Linux Mark Rivers
Next: Re: Problem with parallel make with seq 2.2.4 on Linux Ben Franksen
