Subject: StreamDevice 2.7.7 won't build with Visual Studio 2010
To: "'Dirk Zimoch'" <[email protected]>
Date: Fri, 13 Jan 2017 17:33:22 +0000
Hi Dirk,
StreamDevice 2.7.7 won’t build with Visual Studio 2010 because that does not define isnan() and isinf(), and those are now used in devaiStream.c.  I have fixed the problem by including epicsMath.h which does define those functions on all supported platforms.  That also let me remove the VxWorks specific definitions of isnan() and isinf() in devaiStream.c.  epicsMath.h was present at least as far back as 3.14.8.  If you want the code to not depend on epicsMath.h then you will need to provide these functions in Windows-specific code as well.
My fixed version is here:
https://github.com/MarkRivers/StreamDevice
and I have made a pull request to your repository:
https://github.com/paulscherrerinstitute/StreamDevice
Prev: Re: Problem with parallel make with seq 2.2.4 on Linux Andrew Johnson
Next: Re: Problem with parallel make with seq 2.2.4 on Linux Ben Franksen
Prev: Re: Problem with parallel make with seq 2.2.4 on Linux Ben Franksen
Next: Support for Rigol DSA815 spectrum analyzer? [RF-128] Konrad, Martin
