Subject: |
Re: Question about EDM installing on Fedora20-64bit operation system----cannot find -lXtst problem |
Gabriel de Souza Fedel <[email protected]> |
To: |
Date: |
Wed, 18 Jan 2017 13:44:36 -0200 |
Hello Zhefu,
apparently is missing libXtst, you should install it probably like this:
sudo yum install libXtst.x86_64 libXtst-devel.x86_64
Em 18-01-2017 13:38, lzf neu escreveu:
I try to compile EDM on Fedora20-64bit operation system and the errors
occured below:
[root@localhost edm]# make
/usr/bin/ld: cannot find -lXtst
collect2: error: ld returned 1 exit status
make[2]: *** [libcfcaa62e-8199-11d3-a77f-00104b8742df.so] Error 1
make[2]: Leaving directory
`/home/user/epics/extensions/src/edm/lib/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/home/user/epics/extensions/src/edm/lib'
make: *** [lib.install] Error 2
Could anyone give me some suggestions and thanks in advance.
Zhefu
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1226
www.lnls.cnpem.br
- Question about EDM installing on Fedora20-64bit operation system----cannot find -lXtst problem lzf neu
Re: CA server bind failure on Windows Andrew Johnson
<2017>
2025
2026
Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
<2017>
2025
2026
