Subject: Problem NFS mounting Centos 7 file systems from vxWorks 5.5
Date: Thu, 19 Jan 2017 01:00:34 +0000
Folks,
We are mostly running VxWorks 6.9.4 now, and with that we have no problem NFS mounting file systems on Centos 7.
However, we have a few IOCs that still need to run VxWorks 5.5.  These can mount file systems on Centos 5 servers fine.  However, on Centos 7 we see the following:
-          The NFS mount command from vxWorks succeeds with no error
-          showmount on the Centos 7 system shows that the vxWorks system has mounted the file system OK
-          However, the vxWorks system cannot actually read or write any files on the file system.
If I type the “ls” command in a valid directory I get
Cant’ open “null”.
Value=-1
The problem is not file permissions, it works fine if we are running the identical IOC with vxWorks 6.9.4, and we have tried setting the files in that directory to mode 755.
Is anyone running vxWorks 5.5 with a Centos 7/ RHEL 7, etc. modern NFS server?  If so, how does one get it to work?
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Torsten Bögershausen
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Jeong Han Lee
Prev: Re: CA server bind failure on Windows Andrew Johnson
Next: Problem compiling StreamDevice on Visual Studio 2015 Mark Rivers
Prev: Re: Question about EDM installing on Fedora20-64bit operation system----cannot find -lXtst problem Gabriel de Souza Fedel
Next: Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Torsten Bögershausen
