Subject: RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5
To: Torsten Bögershausen <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 19 Jan 2017 12:51:36 +0000
> But one observation I made is that Centos 7 uses NFS 4.
> To my understanding NFS 4 does not map the numerical user/group id
> "1:1", by default, but wants to translate the remote user id into a local one in some way.
> And this is a security improvement.
> Can you mount Centos 7 -> Centos 7 ?
Yes, we have successfully NFS mounted Centos 7 file systems from the following systems:
Centos 7
RHEL 6
Fedora 9
Fedora 15
Fedora 23
vxWorks 6.9.4
The only one that does not seem to work is vxWorks 5.5.
Han wrote:
>   Do you enable firewall service?
No, firewalld is not running.
Sent: Thursday, January 19, 2017 12:37 AM
To: Mark Rivers; [email protected]
Subject: Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5
>Is anyone running vxWorks 5.5 with a Centos 7/ RHEL 7, etc. modern NFS server?
Not me.
in some way.
In short: We needed to tweak a file called /etc/idmapd.conf.
I can dig out the details later.
On 19/01/17 02:00, Mark Rivers wrote:
> Folks,
> We are mostly running VxWorks 6.9.4 now, and with that we have no problem NFS
> mounting file systems on Centos 7.
> However, we have a few IOCs that still need to run VxWorks 5.5.  These can
> mount file systems on Centos 5 servers fine.  However, on Centos 7 we see the
> following:
> -          The NFS mount command from vxWorks succeeds with no error
> -          showmount on the Centos 7 system shows that the vxWorks system has
> mounted the file system OK
> -          However, the vxWorks system cannot actually read or write any files
> on the file system.
> If I type the “ls” command in a valid directory I get
> Cant’ open “null”.
> Value=-1
> The problem is not file permissions, it works fine if we are running the
> identical IOC with vxWorks 6.9.4, and we have tried setting the files in that
> directory to mode 755.
> If so, how does one get it to work?
> Thanks,
> Mark
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Ralph Lange
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Jörn Dreyer
Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Torsten Bögershausen
Prev: Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Jeong Han Lee
Next: Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Ralph Lange
Prev: Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Torsten Bögershausen
