Subject: How to write multi value in a caput message?
To: <[email protected]>
Date: Tue, 31 Jan 2017 16:23:03 +0900
Hi all,
While I am working with EPICS, I got a problem. When I am using a SCPI command, I need to send two parameter in a message.
As you can see attached image, need 0~14 number and the other. So, now I used %s(in .proto file) and aao (record in .db file) like this.
setDIS{
out "DISP %s";
record(aao, "$(P)$(R)ST_x_DisPnl"){
field( DESC, "Display")
field( DTYP, "stream")
field( OUT, "@devddg.proto setDIS $(PORT1) $(A)")
That's it. However, I want to control with two parameter like this.
setDIS{
out "DISP %f, %f";
$ caput [PV name] value, value
So, please let me know how I can do.
Pilkyu Jung
Re: How to write multi value in a caput message? Maren Purves
RE: How to write multi value in a caput message? Iain Marcuson
Re: How to write multi value in a caput message? Pearson, Matthew R.
Prev: Re: Problem installing PyEpics Matt Newville
Next: Re: How to write multi value in a caput message? Maren Purves
Prev: Re: Problem installing PyEpics Pete Jemian
