Subject: Re: How to write multi value in a caput message?
To: PilkyuJung <[email protected]>
Cc: "[email protected] list" <[email protected]>
Date: Tue, 31 Jan 2017 14:54:35 +0000
There’s documentation on how to do this on the streamDevice tips & tricks page:
http://epics.web.psi.ch/software/streamdevice/doc/tipsandtricks.html
There’s at least 3 ways to do what you need: waveform/aao, calcout or passing PV names into the protocol function.
Cheers,
Matt
Data Acquisition and Control Engineer
Spallation Neutron Source
Oak Ridge National Lab
> On Jan 31, 2017, at 2:23 AM, PilkyuJung <[email protected]> wrote:
> Hi all,
> While I am working with EPICS, I got a problem. When I am using a SCPI command, I need to send two parameter in a message.
> As you can see attached image, need 0~14 number and the other. So, now I used %s(in .proto file) and aao (record in .db file) like this.
> setDIS{
> out "DISP %s";
> record(aao, "$(P)$(R)ST_x_DisPnl"){
> field( DESC, "Display")
> field( DTYP, "stream")
> field( OUT, "@devddg.proto setDIS $(PORT1) $(A)")
> That's it. However, I want to control with two parameter like this.
> setDIS{
> out "DISP %f, %f";
> $ caput [PV name] value, value
> So, please let me know how I can do.
> Thanks,
> Pilkyu Jung
How to write multi value in a caput message? PilkyuJung
Prev: RE: How to write multi value in a caput message? Iain Marcuson
Next: snl 2.2.4 question Pierrick Hanlet
