Subject: seq 2.2.4 problem?
To: "'Ben Franksen'" <[email protected]>
Date: Tue, 31 Jan 2017 19:26:48 +0000
Hi Ben,
We upgraded our beamlines from base 3.14.12.5 and seq 2.2.3 to base 3.15.5 and seq 2.2.4.
This morning we observed a problem with Channel Access Security from ca_array_put from an SNL program which we had not seen before, and are wondering if it could be related to a change in the version of seq.
Configuration:
-          A soft IOC (linux-x86_64) runs an SNL program that controls an undulator at the APS.
-          The APS undulator is behind a PV Gateway, and implements Channel Access Security.  Only certain computers and accounts are allowed to control the undulator, and they are only allowed to control it in user-beam mode, not during studies modes.
-          We started our the IOC when the APS was in studies mode, so the SNL program was not allowed to write to the undulator.
-          This morning the APS changed to user mode, so the SNL program should have been able to control the undulator.  However, it could not.  We had these errors in our log:
Mon Jan 30 17:58:17 2017sevr=minor ca_array_put(typeToCA(type), count, var->chid, value): Write access denied
Mon Jan 30 17:59:00 2017sevr=minor ca_array_put(typeToCA(type), count, var->chid, value): Write access denied
Tue Jan 31 09:21:58 2017sevr=minor ca_array_put(typeToCA(type), count, var->chid, value): Write access denied
Tue Jan 31 09:22:01 2017sevr=minor ca_array_put(typeToCA(type), count, var->chid, value): Write access denied
Tue Jan 31 09:23:12 2017sevr=minor ca_array_put(typeToCA(type), count, var->chid, value): Write access denied
Note that the errors from Jan. 30 (yesterday) are expected because the APS was in studies mode.  But at 08:00 on Jan. 31 (this morning) the APS switched to user mode and we should have been able to write to the undulator.  However, we could not.
Rebooting our IOC, i.e. restarting the SNL program fixed the problem.
Can you think of any reason why seq 2.2.4 might be causing this issue?  I thought I would ask before I begin to dig deeper and set up test IOCs.
Re: seq 2.2.4 problem? Benjamin Franksen
Prev: pvaPy conda recipe? Lentz, Zachary L
Next: Problem of Running RTEMS/EPiCS Application on BSP altcycv_devkt Jianxium Yan
Next: Re: seq 2.2.4 problem? Benjamin Franksen
