Subject: Problem of Running RTEMS/EPiCS Application on BSP altcycv_devkt
To: [email protected]
Date: Tue, 31 Jan 2017 15:22:00 -0500 (EST)
I can build and run the RTEMS application on the Altera SoC FPGA Board(BSP altcycv_devkit), and it is booted from the startup entry point INit(). But, when I built the RTEMS/EPICS test application, it can't startup with Init().
Does anybody have idea what cause the problem?
BSP: altcycv_devkit
RTEMS version 4.11
EPICS base-3.15.1
The following shows the linker format when I run "make" for test application.
/home/yanjx/workspace/rtems411/bin/arm-rtems4.11-g++ -B/home/yanjx/workspace/rtems411/arm-rtems4.11/altcycv_devkit/lib/ -specs bsp_specs -qrtems   -o test -static -L/home/yanjx/workspace/epics/test/lib/RTEMS-altcycv_devkit -L/home/yanjx/workspace/epics/base-3.15.1/lib/RTEMS-altcycv_devkit   -march=armv7-a -mthumb -mfpu=vfp -mfloat-abi=softfp -mtune=cortex-a9 -u Init            test_registerRecordDeviceDriver.o testMain.o    -ltestSupport -ldbRecStd -ldbCore -lca -lCom  -lm -lrtemsCom -lc -lrtemscpu -lrtemsbsp -lCom -lnfs -lm
/home/yanjx/workspace/rtems411/bin/arm-rtems4.11-objcopy -O binary -R .comment -S test test.boot
I also attached the RTEMS configuration and init files on the folder of epics/base-3.15.1/src/libCom/RTEMS, and the testMain.cpp on the folder testApp/src.
Any advice would be appreciated.
Jay Yan
* Copyright (c) 2002 The University of Saskatchewan
* EPICS BASE Versions 3.13.7
* and higher are distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
 * RTEMS configuration for EPICS
 *  Revision-Id: [email protected]
 *      Author: W. Eric Norum
 *              [email protected]
 *              (630) 252-4793
#include <rtems.h>
#define RTEMS_DEBUG
 *                         RTEMS CONFIGURATION                         *
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#if __RTEMS_MAJOR__>4 || (__RTEMS_MAJOR__==4 && __RTEMS_MINOR__>9) || (__RTEMS_MAJOR__==4 && __RTEMS_MINOR__==9 && __RTEMS_REVISION__==99)
#  define CONFIGURE_UNIFIED_WORK_AREAS
#else
#  define CONFIGURE_EXECUTIVE_RAM_SIZE (2048*1024)
#endif
#define CONFIGURE_EXECUTIVE_RAM_SIZE (2048*1024)
#define CONFIGURE_MAXIMUM_TASKS             rtems_resource_unlimited(30)
#define CONFIGURE_MAXIMUM_SEMAPHORES        rtems_resource_unlimited(500)
#define CONFIGURE_MAXIMUM_TIMERS            rtems_resource_unlimited(20)
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES    rtems_resource_unlimited(5)
#define CONFIGURE_MAXIMUM_USER_EXTENSIONS   1
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 150
#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
#define CONFIGURE_MAXIMUM_DRIVERS       8
#define CONFIGURE_MICROSECONDS_PER_TICK 20000
#define CONFIGURE_INIT_TASK_PRIORITY    80
#define CONFIGURE_MALLOC_STATISTICS     1
#define CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
                    RTEMS_NO_TIMESLICE | \
                    RTEMS_NO_ASR | \
                    RTEMS_INTERRUPT_LEVEL(0))
#define CONFIGURE_INIT_TASK_ATTRIBUTES (RTEMS_FLOATING_POINT | RTEMS_LOCAL)
#define CONFIGURE_INIT_TASK_STACK_SIZE  (32*1024)
rtems_task Init (rtems_task_argument argument);
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_FILESYSTEM_NFS
#define CONFIGURE_FILESYSTEM_IMFS
 * This should be made BSP dependent, not CPU dependent but I know of no
 * appropriate conditionals to use.
 * The new general time support makes including the RTC driverr less important.
#if !defined(mpc604) && !defined(__mc68040__) && !defined(__mcf5200__) && !defined(mpc7455) && !defined(__arm__)  && !defined(__nios2__)/* don't have RTC code */
#define CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
#endif
#include <bsp.h>
#include <rtems/confdefs.h>
 * RTEMS startup task for EPICS
 *              [email protected]
 *              (306) 966-5394
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <ctype.h>
#include <time.h>
#include <errno.h>
#include <fcntl.h>
#include <sys/termios.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <rtems.h>
#include <rtems/malloc.h>
#include <rtems/error.h>
#include <rtems/stackchk.h>
#include <rtems/rtems_bsdnet.h>
#include <rtems/imfs.h>
#include <librtemsNfs.h>
#include <bsp.h>
#include <rtems/libio.h>
#include <sys/stat.h>
#include "epicsThread.h"
#include "epicsTime.h"
#include "epicsExit.h"
#include "envDefs.h"
#include "errlog.h"
#include "logClient.h"
#include "osiUnistd.h"
#include "iocsh.h"
#include "osdTime.h"
#include "epicsRtemsInitHooks.h"
#include <rtems/score/heap.h>
#include <pthread.h>
int Init_Done =0;
 * Prototypes for some functions not in header files
void tzset(void);
int fileno(FILE *);
int main(int argc, char **argv);
int epicsThreadGetOssPriorityValue(unsigned int osiPriority)
	if (osiPriority > 99) {
		return 100;
	else {
		return (199- (signed int)osiPriority);
//static void
void logReset (void)
    void rtems_bsp_reset_cause(char *buf, size_t capacity) __attribute__((weak));
    void (*fp)(char *buf, size_t capacity) = rtems_bsp_reset_cause;
    if (fp) {
        char buf[80];
        fp(buf, sizeof buf);
        errlogPrintf ("Startup after %s.\n", buf);
printk("Startup after %s. \n", buf);
    else {
        errlogPrintf ("Startup.\n");
printk("Startup.\n");
 *                         FATAL ERROR REPORTING                       *
 * Delay for a while, then terminate
static void
delayedPanic (const char *msg)
	rtems_task_wake_after(rtems_clock_get_ticks_per_second());
	extern rtems_interval rtemsTicksPerSecond;
    rtems_task_wake_after (rtemsTicksPerSecond);
	rtems_panic (msg);
 * Log error and terminate
void
LogFatal (const char *msg, ...)
    va_list ap;
    va_start (ap, msg);
    errlogVprintf (msg, ap);
    va_end (ap);
    delayedPanic (msg);
 * Log RTEMS error and terminate
void
LogRtemsFatal (const char *msg, rtems_status_code sc)
    errlogPrintf ("%s: %s\n", msg, rtems_status_text (sc));
    delayedPanic (msg);
 * Log network error and terminate
void
LogNetFatal (const char *msg, int err)
    errlogPrintf ("%s: %d\n", msg, err);
    delayedPanic (msg);
void *
mustMalloc(int size, const char *msg)
    void *p;
    if ((p = malloc (size)) == NULL)
        LogFatal ("Can't allocate space for %s.\n", msg);
    return p;
 *                         REMOTE FILE ACCESS                          *
#ifdef OMIT_NFS_SUPPORT
# include <rtems/tftp.h>
#endif
static int
initialize_local_filesystem(char **argv)
    extern char _DownloadLocation[] __attribute__((weak));
    extern char _FlashBase[] __attribute__((weak));
    extern char _FlashSize[]  __attribute__((weak));
    argv[0] = rtems_bsdnet_bootp_boot_file_name;
    if (_FlashSize && (_DownloadLocation || _FlashBase)) {
    //    extern char _edata[];
    char *_edata = ".";
        size_t flashIndex = _edata - _DownloadLocation;
        char *header = _FlashBase + flashIndex;
        if (memcmp(header + 257, "ustar  ", 8) == 0) {
            int fd;
            printf ("***** Unpack in-memory file system (IMFS) *****\n");
            if (rtems_tarfs_load("/", (unsigned char *)header, (size_t)_FlashSize - flashIndex) != 0) {
                printf("Can't unpack tar filesystem\n");
                return 0;
            if ((fd = open(rtems_bsdnet_bootp_cmdline, 0)) >= 0) {
                close(fd);
                printf ("***** Found startup script (%s) in IMFS *****\n", rtems_bsdnet_bootp_cmdline);
                argv[1] = rtems_bsdnet_bootp_cmdline;
                return 1;
            printf ("***** Startup script (%s) not in IMFS *****\n", rtems_bsdnet_bootp_cmdline);
    return 0;
#ifndef OMIT_NFS_SUPPORT
#if __RTEMS_MAJOR__>4 || \
   (__RTEMS_MAJOR__==4 && __RTEMS_MINOR__>9) || \
int
nfsMount(char *uidhost, char *path, char *mntpoint)
    int   devl = strlen(uidhost) + strlen(path) + 2;
    char *dev;
    int   rval = -1;
    if ((dev = malloc(devl)) == NULL) {
        fprintf(stderr,"nfsMount: out of memory\n");
        return -1;
    sprintf(dev, "%s:%s", uidhost, path);
    printf("Mount %s on %s\n", dev, mntpoint);
    if (rtems_mkdir(mntpoint, S_IRWXU | S_IRWXG | S_IRWXO))
        printf("Warning -- unable to make directory \"%s\"\n", mntpoint);
    if (mount(dev, mntpoint, RTEMS_FILESYSTEM_TYPE_NFS,
                             RTEMS_FILESYSTEM_READ_WRITE, NULL)) {
        perror("mount failed");
    else {
        rval = 0;
    free(dev);
    return rval;
#define NFS_INIT
#else
#define NFS_INIT    rpcUdpInit(); nfsInit(0,0);
#endif
#endif
static void
initialize_remote_filesystem(char **argv, int hasLocalFilesystem)
    printf ("***** Initializing TFTP *****\n");
    mount_and_make_target_path(NULL,
                               "/TFTP",
                               RTEMS_FILESYSTEM_TYPE_TFTPFS,
                               NULL);
#else
    rtems_bsdnet_initialize_tftp_filesystem ();
#endif
    if (!hasLocalFilesystem) {
        char *path;
        int pathsize = 200;
        int l;
        path = mustMalloc(pathsize, "Command path name ");
        strcpy (path, "/TFTP/BOOTP_HOST/epics/");
        l = strlen (path);
        if (gethostname (&path[l], pathsize - l - 10) || (path[l] == '\0'))
            LogFatal ("Can't get host name");
        strcat (path, "/st.cmd");
        argv[1] = path;
#else
    char *server_name;
    char *server_path;
    char *mount_point;
    char *cp;
    int l = 0;
    printf ("***** Initializing NFS *****\n");
    NFS_INIT
    if (env_nfsServer && env_nfsPath && env_nfsMountPoint) {
        server_name = env_nfsServer;
        server_path = env_nfsPath;
        mount_point = env_nfsMountPoint;
        cp = mount_point;
        while ((cp = strchr(cp+1, '/')) != NULL) {
            *cp = '\0';
            if ((mkdir (mount_point, 0755) != 0)
             && (errno != EEXIST))
                LogFatal("Can't create directory \"%s\": %s.\n",
                                                mount_point, strerror(errno));
            *cp = '/';
    else if (hasLocalFilesystem) {
        return;
    else {
         * Use first component of nvram/bootp command line pathname
         * to set up initial NFS mount.  A "/tftpboot/" is prepended
         * if the pathname does not begin with a '/'.  This allows
         * NFS and TFTP to have a similar view of the remote system.
        if (rtems_bsdnet_bootp_cmdline[0] == '/')
            cp = rtems_bsdnet_bootp_cmdline + 1;
        else
            cp = rtems_bsdnet_bootp_cmdline;
        cp = strchr(cp, '/');
        if ((cp == NULL)
         || ((l = cp - rtems_bsdnet_bootp_cmdline) == 0))
            LogFatal("\"%s\" is not a valid command pathname.\n", rtems_bsdnet_bootp_cmdline);
        cp = mustMalloc(l + 20, "NFS mount paths");
        server_path = cp;
        server_name = rtems_bsdnet_bootp_server_name;
        if (rtems_bsdnet_bootp_cmdline[0] == '/') {
            mount_point = server_path;
            strncpy(mount_point, rtems_bsdnet_bootp_cmdline, l);
            mount_point[l] = '\0';
             * Its probably common to embed the mount point in the server
             * name so, when this is occurring, dont clobber the mount point
             * by appending the first node from the command path. This allows
             * the mount point to be a different path then the server's mount
             * path.
             * This allows for example a line similar to as follows the DHCP
             * configuration file.
             * server-name "[email protected]:/vol/vol0/bootRTEMS";
            if ( server_name ) {
                const size_t allocSize = strlen ( server_name ) + 2;
                char * const pServerName = mustMalloc( allocSize,
                                                        "NFS mount paths");
                char * const pServerPath = mustMalloc ( allocSize,
                                                        "NFS mount paths");
                const int scanfStatus = sscanf (
                                          server_name,
                                          "%[^:] : / %s",
                                          pServerName,
                                          pServerPath + 1u );
                if ( scanfStatus ==  2 ) {
                    pServerPath[0u]= '/';
                    server_name = pServerName;
                    server_path = pServerPath;
                else {
                    free ( pServerName );
                    free ( pServerPath );
        else {
            char *abspath = mustMalloc(strlen(rtems_bsdnet_bootp_cmdline)+2,"Absolute command path");
            strcpy(server_path, "/tftpboot/");
            mount_point = server_path + strlen(server_path);
            mount_point--;
            strcpy(abspath, "/");
            strcat(abspath, rtems_bsdnet_bootp_cmdline);
            argv[1] = abspath;
	int rv;
	rv = mount_and_make_target_path(
		server_name,
		server_path,
		NULL
//    nfsMount(server_name, server_path, mount_point);
#endif
 * Get to the startup script directory
 * The TFTP filesystem requires a trailing '/' on chdir arguments.
static void
set_directory (const char *commandline)
    const char *cp;
    char *directoryPath;
    int l;
    cp = strrchr(commandline, '/');
    if (cp == NULL) {
        l = 0;
        cp = "/";
    else {
        l = cp - commandline;
        cp = commandline;
    directoryPath = mustMalloc(l + 2, "Command path directory ");
    strncpy(directoryPath, cp, l);
    directoryPath[l] = '/';
    directoryPath[l+1] = '\0';
    if (chdir (directoryPath) < 0)
        LogFatal ("Can't set initial directory(%s): %s\n", directoryPath, strerror(errno));
    free(directoryPath);
 *                         RTEMS/EPICS COMMANDS                        *
 * RTEMS status
static void
rtems_netstat (unsigned int level)
    rtems_bsdnet_show_if_stats ();
    rtems_bsdnet_show_mbuf_stats ();
    if (level >= 1) {
        rtems_bsdnet_show_inet_routes ();
    if (level >= 2) {
        rtems_bsdnet_show_ip_stats ();
        rtems_bsdnet_show_icmp_stats ();
        rtems_bsdnet_show_udp_stats ();
        rtems_bsdnet_show_tcp_stats ();
static const iocshArg netStatArg0 = { "level",iocshArgInt};
static const iocshArg * const netStatArgs[1] = {&netStatArg0};
static const iocshFuncDef netStatFuncDef = {"netstat",1,netStatArgs};
static void netStatCallFunc(const iocshArgBuf *args)
    rtems_netstat(args[0].ival);
static const iocshFuncDef heapSpaceFuncDef = {"heapSpace",0,NULL};
static void heapSpaceCallFunc(const iocshArgBuf *args)
    rtems_malloc_statistics_t s;
    double x;
    malloc_get_statistics(&s);
    x = s.space_available - (unsigned long)(s.lifetime_allocated - s.lifetime_freed);
   Heap_Information_block info;
   double x;
  malloc_info(&info);
  x = info.Stats.size - (unsigned long)(info.Stats.lifetime_allocated - info.Stats.lifetime_freed);
    if (x >= 1024*1024)
        printf("Heap space: %.1f MB\n", x / (1024 * 1024));
    else
        printf("Heap space: %.1f kB\n", x / 1024);
static const iocshArg nfsMountArg0 = { "[uid.gid@]host",iocshArgString};
static const iocshArg nfsMountArg1 = { "server path",iocshArgString};
static const iocshArg nfsMountArg2 = { "mount point",iocshArgString};
static const iocshArg * const nfsMountArgs[3] = {&nfsMountArg0,&nfsMountArg1,
                                                 &nfsMountArg2};
static const iocshFuncDef nfsMountFuncDef = {"nfsMount",3,nfsMountArgs};
static void nfsMountCallFunc(const iocshArgBuf *args)
    char *cp = args[2].sval;
        *cp = '\0';
        if ((mkdir (args[2].sval, 0755) != 0) && (errno != EEXIST)) {
            printf("Can't create directory \"%s\": %s.\n",
                                            args[2].sval, strerror(errno));
            return;
        *cp = '/';
    nfsMount(args[0].sval, args[1].sval, args[2].sval);
#endif
 * Register RTEMS-specific commands
//static
void iocshRegisterRTEMS (void)
    iocshRegister(&netStatFuncDef, netStatCallFunc);
    iocshRegister(&heapSpaceFuncDef, heapSpaceCallFunc);
    iocshRegister(&nfsMountFuncDef, nfsMountCallFunc);
#endif
 * Set up the console serial line (no handshaking)
//static void
void initConsole (void)
    struct termios t;
printk(" initConsole() \n");
    if (tcgetattr (fileno (stdin), &t) < 0) {
        printf ("tcgetattr failed: %s\n", strerror (errno));
        return;
    t.c_iflag &= ~(IXOFF | IXON | IXANY);
    if (tcsetattr (fileno (stdin), TCSANOW, &t) < 0) {
        printf ("tcsetattr failed: %s\n", strerror (errno));
        return;
 * Ensure that the configuration object files
 * get pulled in from the library
extern const rtems_configuration_table Configuration;
extern struct rtems_bsdnet_config rtems_bsdnet_config;
const void *rtemsConfigArray[] = {
    &Configuration,
    &rtems_bsdnet_config
 * Hook to ensure that BSP cleanup code gets run on exit
static void
exitHandler(void)
    rtems_shutdown_executive(0);
 * RTEMS Startup task
rtems_task
Init (rtems_task_argument ignored)
    int                 i;
    char               *argv[3]         = { NULL, NULL, NULL };
    char               *cp;
    rtems_task_priority newpri;
    rtems_status_code   sc;
    rtems_time_of_day   now;
     * Explain why we're here
   Init_Done = 1;
printk("**** Starting RTEMS/EPICS ****");
    logReset();
     * Architecture-specific hooks
    if (epicsRtemsInitPreSetBootConfigFromNVRAM(&rtems_bsdnet_config) != 0)
        delayedPanic("epicsRtemsInitPreSetBootConfigFromNVRAM");
    if (rtems_bsdnet_config.bootp == NULL) {
        extern void setBootConfigFromNVRAM(void);
        setBootConfigFromNVRAM();
    if (epicsRtemsInitPostSetBootConfigFromNVRAM(&rtems_bsdnet_config) != 0)
        delayedPanic("epicsRtemsInitPostSetBootConfigFromNVRAM");
     * Override RTEMS configuration
pthread_attr_t attr;
struct sched_param param;
int newprio = (int)((double) epicsThreadPriorityIocsh * (254.0 - 1.0)/100.0);
if (pthread_attr_getschedparam(&attr, &param) !=0)
delayedPanic("pthread_attr_getschedparam failed");
param.sched_priority = newprio;
if (pthread_attr_setschedparam(&attr, &param) != 0)
	delayedPanic("pthread_attr_setschedparam failed");
    rtems_task_set_priority (
                     RTEMS_SELF,
                     epicsThreadGetOssPriorityValue(epicsThreadPriorityIocsh),
                     &newpri);
     * Create a reasonable environment
    initConsole ();
    putenv ("TERM=xterm");
    putenv ("IOCSH_HISTSIZE=20");
     * Start network
    if ((cp = getenv("EPICS_TS_NTP_INET")) != NULL)
        rtems_bsdnet_config.ntp_server[0] = cp;
    if (rtems_bsdnet_config.network_task_priority == 0)
        unsigned int p;
        if (epicsThreadHighestPriorityLevelBelow(epicsThreadPriorityScanLow, &p)
                                            == epicsThreadBooleanStatusSuccess)
            rtems_bsdnet_config.network_task_priority = epicsThreadGetOssPriorityValue(p);
    printf("\n***** Initializing network *****\n");
    rtems_bsdnet_initialize_network();
    initialize_remote_filesystem(argv, initialize_local_filesystem(argv));
     * More environment: iocsh prompt and hostname
        char hostname[1024];
        gethostname(hostname, 1023);
        char *cp = mustMalloc(strlen(hostname)+3, "iocsh prompt");
        sprintf(cp, "%s> ", hostname);
        epicsEnvSet ("IOCSH_PS1", cp);
        epicsEnvSet("IOC_NAME", hostname);
     * Use BSP-supplied time of day if available otherwise supply default time.
     * It is very likely that other time synchronization facilities in EPICS
     * will soon override this value.
    if (rtems_clock_get(RTEMS_CLOCK_GET_TOD,&now) != RTEMS_SUCCESSFUL) {
        now.year = 2001;
        now.month = 1;
        now.day = 1;
        now.hour = 0;
        now.minute = 0;
        now.second = 0;
        now.ticks = 0;
        if ((sc = rtems_clock_set (&now)) != RTEMS_SUCCESSFUL)
            printf ("***** Can't set time: %s\n", rtems_status_text (sc));
    if (getenv("TZ") == NULL) {
        const char *tzp = envGetConfigParamPtr(&EPICS_TIMEZONE);
        if (tzp == NULL) {
            printf("Warning -- no timezone information available -- times will be displayed as GMT.\n");
        else {
            char tz[10];
            int minWest, toDst = 0, fromDst = 0;
            if(sscanf(tzp, "%9[^:]::%d:%d:%d", tz, &minWest, &toDst, &fromDst) < 2) {
                printf("Warning: EPICS_TIMEZONE (%s) unrecognizable -- times will be displayed as GMT.\n", tzp);
            else {
                char posixTzBuf[40];
                char *p = posixTzBuf;
                p += sprintf(p, "%cST%d:%.2d", tz[0], minWest/60, minWest%60);
                if (toDst != fromDst)
                    p += sprintf(p, "%cDT", tz[0]);
                epicsEnvSet("TZ", posixTzBuf);
    tzset();
    osdTimeRegister();
     * Run the EPICS startup script
    printf ("***** Starting EPICS application *****\n");
    iocshRegisterRTEMS ();
    set_directory (argv[1]);
    epicsEnvSet ("IOC_STARTUP_SCRIPT", argv[1]);
    atexit(exitHandler);
    i = main ((sizeof argv / sizeof argv[0]) - 1, argv);
    printf ("***** IOC application terminating *****\n");
    epicsThreadSleep(1.0);
    epicsExit(0);
/* testMain.cpp */
/* Author:  Marty Kraimer Date:    17MAR2000 */
#include <stddef.h>
#include <stdlib.h>
#include <stddef.h>
#include <string.h>
#include <stdio.h>
#include "iocsh.h"
int main(int argc,char *argv[])
    if(argc>=2) {
        iocsh(argv[1]);
        epicsThreadSleep(.2);
    iocsh(NULL);
    epicsExit(0);
    return(0);
Prev: seq 2.2.4 problem? Mark Rivers
Next: Re: snl 2.2.4 question Benjamin Franksen
Prev: Re: seq 2.2.4 problem? Benjamin Franksen
Next: Announcing the Transient Recorder Framework ambroz . bizjak
