Start with this prefix: http://htmlpreview.github.io/?
Like this:
http://htmlpreview.github.io/?https://raw.githubusercontent.com/epics-modules/motor/master/documentation/motorDeviceDriver.html
Sent from a device with a dreadfully small screen
-------- Original message -------- From: Torsten Bögershausen <[email protected]> Date: 2/7/17 5:53 AM (GMT-06:00) To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]> Subject: Re: How to support a new stepper motor controller? Not sure how to make this page look nice Pete ? <https://raw.githubusercontent.com/epics-modules/motor/master/documentation/motorDeviceDriver.html> And the good stuff is here: <https://github.com/epics-modules/motor/blob/master/motorApp/AcsSrc/MCB4BDriver.cpp> HTH /Torsten PS: I would probably suggest to start with a simulator. Let's see if I can dig out one. On 07/02/17 10:53, Ralph Lange wrote: > Dear motion specialists, > > I am writing on behalf of Paramveer Jain (in CC) who has contacted me with this > issue, but as I have never done motion control integration with EPICS, I'd > rather throw this ball up than send him into the wrong direction. > > He is being tasked with developing EPICS support for a locally developed motor > controller. > > The hardware setup can be summarized as: > > * Moxa embedded TCP-to-serial converter (NE4110S) > * Serial connection (RS-232) > * Homemade motor controller (based on an AT89C52) > * Ark Motion AMS 3630 stepper motor driver. > > The controller software talks ASCII in command/response fashion, e.g.: > > * Read position (rotary encoder) > Command: STX U <CR> > Response: STX U pppppp <CR> > pppppp = six digit hex (divide by 640 to get millimeter) > * Go to position (rotary encoder) > Command: STX P1 sss pppppp <CR> > Response: \06 (ACK) > sss = three digit hex (speed in mm/s multiplied by 240) > pppppp = six digit hex (millimeter multiplied by 640) > * ... > > What's the best/easiest way to do this? What are the caveats? > Is there a tutorial he could follow? > Is there existing support for another motor that he could start from? > > Thanks a lot for your help! > ~Ralph >
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
