Subject: Re: Sequencer remote pvPut CA delay (specified behavior?)
To: EPICS Techtalk <[email protected]>
Date: Tue, 14 Feb 2017 14:45:19 +0100
On 13.02.2017 23:53, Andrew Johnson wrote:
> [...] Consider rewriting the state machine and
> using a separate when(delay(5)) state transition for the delay instead.
> I think doing this will also have an effect on your results; I don't
> know the internals of the sequencer, but I suspect it flushes the CA
> output queue at the end of each set of actions, not between individual
> action statements.
Yes. More specifically, CA output buffer always gets flushed right
before a state set thread blocks in order to wait for an event, i.e.
 * before when-conditions in a state are evaluated, and
 * whenever pvGet or pvPut are called with the extra SYNC flag that
   makes them wait for completion.
> Your epicsThreadSleep() call appears in the middle of
> the set of actions though, so a flush at the end of the when() {} block
> won't have a chance to run until after the second pvPut() call has run
> anyway, thus causing the effect that you're seeing.
Yes, I also guess this is the reason for the behaviour Tobin sees.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
Sequencer remote pvPut CA delay (specified behavior?) Tobin Weber
Re: Sequencer remote pvPut CA delay (specified behavior?) Andrew Johnson
Prev: Re: Driver for New Focus 8732 Picomotor Multi-Axis Driver Nilson Pereira
Next: RE: Logbook entry error Patard Charles-Henri
Prev: Re: Sequencer remote pvPut CA delay (specified behavior?) Tobin Weber
Next: Problem compiling areaDetector-2-5 Marcin Lukaszewski
