Subject: Re: memory leak after unloading of ca.lib
To: Michael Davidsaver <[email protected]>
Date: Fri, 24 Feb 2017 18:46:44 +0100
Hi Michael,
thanks for your help.
I wrote a stub library first, before I got the memory issues. It worked very well (since 2010) in Windows at 32-bit and 64-bit. In Linux 32-bit I could avoid the problem with delayed unloading the stub lib. Now I want to support Linux 64-bit too. But the delay trick doesn't work in that environment. That's the full story. You see, I have an old project that's running into problems under special conditions.
Do you have any other advice for me?
Best regards
Carsten
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: memory leak after unloading of ca.lib Michael Davidsaver
memory leak after unloading of ca.lib Carsten Winkler
Re: memory leak after unloading of ca.lib Ben Franksen
RE: memory leak after unloading of ca.lib Hill, Jeff
Re: memory leak after unloading of ca.lib Carsten Winkler
Prev: Re: Why we want Lua on the IOC Kevin Peterson
Next: Re: streamDevice protocol - accept two different valid responses Ford, Christopher
Prev: Re: memory leak after unloading of ca.lib Michael Davidsaver
Next: Re: memory leak after unloading of ca.lib Michael Davidsaver
