Subject: Re: memory leak after unloading of ca.lib
To: "Carsten Winkler (HZB)" <[email protected]>
Date: Fri, 24 Feb 2017 15:33:55 -0500
On 02/24/2017 12:46 PM, Carsten Winkler (HZB) wrote:
> Hi Michael,
> thanks for your help.
> I wrote a stub library first, before I got the memory issues. It worked
> very well (since 2010) in Windows at 32-bit and 64-bit. In Linux 32-bit
> I could avoid the problem with delayed unloading the stub lib. Now I
> want to support Linux 64-bit too. But the delay trick doesn't work in
> that environment. That's the full story. You see, I have an old project
> that's running into problems under special conditions.
> Do you have any other advice for me?
Other the totally unhelpful suggestion not to use labview ;) you could
have your stub library use dlopen() instead of .so dependencies.
> Best regards
> Carsten
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
> Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende
> Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
Re: memory leak after unloading of ca.lib Carsten Winkler
Re: memory leak after unloading of ca.lib Michael Davidsaver
Re: memory leak after unloading of ca.lib Ben Franksen
RE: memory leak after unloading of ca.lib Hill, Jeff
Re: memory leak after unloading of ca.lib Carsten Winkler (HZB)
Prev: Re: streamDevice protocol - accept two different valid responses Ford, Christopher
Next: RE: Why we want Lua on the IOC Lang, Keenan C.
Prev: Re: memory leak after unloading of ca.lib Carsten Winkler (HZB)
Next: Re: memory leak after unloading of ca.lib Carsten Winkler
