Subject: RE: Why we want Lua on the IOC
To: "Peterson, Kevin M." <[email protected]>, "Hill, Jeff" <[email protected]>, Ben Franksen <[email protected]>
Cc: "Tech Talk \([email protected]\)" <[email protected]>
Date: Fri, 24 Feb 2017 20:53:15 +0000
It's not Jeff's code, but if anyone wants to play around with Lua in EPICS, there's a Lua module in the synApps github project that has implemented much of the same stuff.
https://github.com/epics-modules/script
It has a lua replacement for the calc record, a lua IOC shell (though it requires the current development version of base-3.16), library linkages into asyn for communication with devices, and device support to use lua with regular record types. It's also been the basis for a motor driver that allows lua to be used to write motor controllers.
https://github.com/epics-modules/motor/pull/40
Documentation is a bit spotty, though. But the examples should be enough to get someone started.
Keenan
From: [email protected] [[email protected]] on behalf of Kevin Peterson [[email protected]]
Sent: Friday, February 24, 2017 10:59 AM
To: Hill, Jeff; Ben Franksen
Cc: Tech Talk ([email protected])
Subject: Re: Why we want Lua on the IOC
Jeff,
The things you've implemented so far sound really interesting and
useful.  Is any of the code on github?
Kevin
On 2/23/17 4:19 PM, Hill, Jeff wrote:
> Hi Ben,
> For reference, I have presented some talks on this topic at the last few EPICS meetings.
> So far I have implemented the following.
> o A Lua-based CA server event filtering system where a small Lua snippet in the channel name postfix serves as the filter
> o A Lua-based IOC shell, callable from the legacy IOC shell, which can also invoke all of the registered IOC shell commands
> o A Lua-based scripting record, where Lua provides a comprehensive feature set, compared to CALC.
> Thanks for your interest,
> Jeff
RE: Why we want Lua on the IOC Hill, Jeff
Re: Why we want Lua on the IOC Kevin Peterson
Prev: Re: memory leak after unloading of ca.lib Michael Davidsaver
Next: RE: Why we want Lua on the IOC Hill, Jeff
Prev: Re: Why we want Lua on the IOC Kevin Peterson
