1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Asyn 4-30 Problem on Arm processor
To: [email protected]
Date: Fri, 17 Mar 2017 13:02:22 +0100
Hi Mark,
I could not use StreamDevice because of hardware issues. It turned out that
these devices need special configurations of the serial interface which can not
be set using the standard asynSerialPort driver. In addition there are some
commands that need to combine the values from more than one PV into the output
stream.
Removing PINI in all records did not change the result.
I'm trying now which of the records is causing the problem.
As soon as I include one record with type asynFloat64 it crashes.
 I will try tu run the code on x86_64 under vagrind and see what happens.
Jörn
RE: Asyn 4-30 Problem on Arm processor Mark Rivers
Asyn 4-30 Problem on Arm processor Jörn Dreyer
Re: Asyn 4-30 Problem on Arm processor Jörn Dreyer
Prev: RE: Asyn 4-30 Problem on Arm processor Mark Rivers
Next: RE: Asyn 4-30 Problem on Arm processor Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
