Did you set the asynFloat64Mask bit in your call to the asynPortDriver base class constructor?
Perhaps you should send me your driver files.
From: [email protected] [[email protected]] on behalf of Jörn Dreyer [[email protected]]
Sent: Friday, March 17, 2017 7:02 AM
To: [email protected]
Subject: Re: Asyn 4-30 Problem on Arm processor
Hi Mark,
I could not use StreamDevice because of hardware issues. It turned out that
these devices need special configurations of the serial interface which can not
be set using the standard asynSerialPort driver. In addition there are some
commands that need to combine the values from more than one PV into the output
stream.
Removing PINI in all records did not change the result.
I'm trying now which of the records is causing the problem.
As soon as I include one record with type asynFloat64 it crashes.
I will try tu run the code on x86_64 under vagrind and see what happens.
Jörn
- Asyn 4-30 Problem on Arm processor Jörn Dreyer
- Re: Asyn 4-30 Problem on Arm processor Jörn Dreyer
- RE: Asyn 4-30 Problem on Arm processor Mark Rivers
Re: Asyn 4-30 Problem on Arm processor Konrad, Martin
<2017>
2025
<2017>
2025
