Subject: |
[AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays |
Paweł Plewiński <[email protected]> |
To: |
[email protected] |
Date: |
Tue, 11 Apr 2017 15:49:01 +0200 |
I've recently written asyn-based device support for a custom device
communicating over PCIe. One of its functions is to periodically
retrieve 4 waveforms from 4 channels, which is done in a separate
thread, from which the callback function is called to notify asyn about
change. I heavily based the code on the AsynPortDriver example.
The driver works, however if the update rate is lower than 1 second,
strange warning appears in the console at the time of every refresh (and
that's only for one of 4 channels), namely:
2017/04/11 15:42:08.682 PIEZO:OSC-CH0-WAVEFORM
devAsynFloat64Array::interruptCallbackInput
\000\000\000\000\000@\205?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?\000\000\000\000\000\000\204?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?\000\000\000\000\000@\205?\000\000\000\000\000\000\204?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?
devAsynFloat64Array::processCommon, warning, multiple interrupt
The parameters passed to the top level constructor are
: asynPortDriver(portName,
4, /* maxAddr */
(int)NUM_SCOPE_PARAMS,
asynInt32Mask | asynFloat64Mask |
asynFloat64ArrayMask | asynEnumMask | asynDrvUserMask, /* Interface mask
asynFloat64ArrayMask | asynEnumMask, /* Interrupt mask */
ASYN_MULTIDEVICE, /* asynFlags. This driver does
not block and it is not multi-device, so flag is 0 */
1, /* Autoconnect */
0, /* Default priority */
0) /* Default stack size*/
The readback thread code:
void piezoPortDriver::readbackTask(void)
while (1) {
bool stopped = false;
lock();
auto new_data = osc->fetch_data(vtim, vdat);
unlock();
if (!stopped)
lock();
this->osc_update_trigger();
unlock();
callParamCallbacks();
for (int i = 0; i < 4; i++){
doCallbacksFloat64Array(vdat[i].data(), vdat[i].size(),
P_OscWaveform, i);
usleep(100000);
The fetch_data method reads four 1000-element double vectors from PCIe.
Could you give me some suggestions what may be wrong?
Paweł Plewiński
Department of Microelectronics and Computer Science
Lodz University of Technology
- RE: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Mark Rivers
RE: Asyn timeout Mark Rivers
Re: CA client within Asyn Eric Norum
<2017>
Re: Archiver Appliance established multiple CA connections for one channel Wang, Lin
<2017>
