1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays
To: EPICS Tech Talk <[email protected]>
Date: Tue, 11 Apr 2017 20:06:25 +0200
But why is it only reporting for the first of the four channels?
Could it be that for that ASYN_MULTIDEVICE the callbacks are somehow all counted for the first channel?
Pretty clueless,
~Ralph
On Tue, Apr 11, 2017 at 6:24 PM, Mark Rivers <[email protected]> wrote:
Hi Pawel,
What is the SCAN field of your waveform record?  I suspect it is probably periodic ("1 second", etc.).  For this application you should set it to SCAN="I/O Intr".  Then the waveform record will process each time your driver does a callback to device support.  If the record is periodically processing at 1 second and your driver is doing callbacks faster than 1 Hz then you will see the error you report.
-----Original Message-----
From: [email protected] [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Pawel Plewinski
Sent: Tuesday, April 11, 2017 8:49 AM
To: [email protected]
Subject: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays
I've recently written asyn-based device support for a custom device
communicating over PCIe. One of its functions is to periodically
retrieve 4 waveforms from 4 channels, which is done in a separate
thread, from which the callback function is called to notify asyn about
change. I heavily based the code on the AsynPortDriver example.
The driver works, however if the update rate is lower than 1 second,
strange warning appears in the console at the time of every refresh (and
that's only for one of 4 channels), namely:
2017/04/11 15:42:08.682 PIEZO:OSC-CH0-WAVEFORM
devAsynFloat64Array::interruptCallbackInput
\000\000\000\000\000@\205?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?\000\000\000\000\000\000\204?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?\000\000\000\000\000@\205?\000\000\000\000\000\000\204?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?
devAsynFloat64Array::processCommon, warning, multiple interrupt
The parameters passed to the top level constructor are
    : asynPortDriver(portName,
                     4, /* maxAddr */
                     (int)NUM_SCOPE_PARAMS,
                     asynInt32Mask | asynFloat64Mask |
asynFloat64ArrayMask | asynEnumMask | asynDrvUserMask, /* Interface mask
asynFloat64ArrayMask | asynEnumMask,  /* Interrupt mask */
                     ASYN_MULTIDEVICE, /* asynFlags.  This driver does
not block and it is not multi-device, so flag is 0 */
                     1, /* Autoconnect */
                     0, /* Default priority */
                     0) /* Default stack size*/
The readback thread code:
void piezoPortDriver::readbackTask(void)
    while (1) {
            bool stopped = false;
            lock();
            auto new_data = osc->fetch_data(vtim, vdat);
            unlock();
            if (!stopped)
                lock();
                this->osc_update_trigger();
                unlock();
         callParamCallbacks();
         for (int i = 0; i < 4; i++){
           doCallbacksFloat64Array(vdat[i].data(), vdat[i].size(),
P_OscWaveform, i);
         usleep(100000);
The fetch_data method reads four 1000-element double vectors from PCIe.
Could you give me some suggestions what may be wrong?
Paweł Plewiński
Department of Microelectronics and Computer Science
Lodz University of Technology
RE: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Mark Rivers
[AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Paweł Plewiński
Prev: RE: CA client within Asyn Mark S. Engbretson
Next: RE: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Mark Rivers
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
