Hi Mark,
thanks for quick answer. Actually I forgot to post the record, but it
had SCAN set to I/O INTR, similarly to the example project. Here's the
record definition:
record(waveform, "PIEZO:OSC-CH$(CHANNEL)-WAVEFORM")
field(DTYP, "asynFloat64ArrayIn")
field(INP, "@asyn($(PORT),$(ADDR),$(TIMEOUT))OSC_WAVEFORM")
field(FTVL, "DOUBLE")
field(NELM, "$(NPOINTS)")
field(LOPR, "0")
field(HOPR, "10")
field(SCAN, "I/O Intr")
As for the commands you asked for, the results are, respectively:
ACKS: NO_ALARM ACKT: YES APST: Always ASG:
ASP: (nil) BKPT: 00 BPTR: 0xbcb3e0 BUSY: 0
DESC: DISA: 0 DISP: 0 DISS:
NO_ALARM
DISV: 1 DPVT: 0xc05690 DSET: 0x7f2dbdcea9a0
DTYP: asynFloat64ArrayIn EGU: EVNT: 0
FLNK:CONSTANT 0 FTVL: DOUBLE HASH: 0 HOPR: 10
INP:INST_IO @asyn(testAPD,0,1)OSC_WAVEFORM LCNT: 0
LOPR: 0 LSET: 0xc07f40
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
MLOK: b0 b3 bc 00 00 00 00 00 MPST: Always
NAME: PIEZO:OSC-CH0-WAVEFORM NELM: 1000 NORD: 1000
NSEV: NO_ALARM NSTA: NO_ALARM PACT: 0 PHAS: 0
PINI: NO PPN: (nil) PPNR: (nil) PREC: 0
PRIO: LOW PROC: 0 PUTF: 0 RARM: 0
RDES: 0xb86470 RPRO: 0 RSET: 0x7f2dbda73340
SCAN: I/O Intr SDIS:CONSTANT SEVR: NO_ALARM
SIML:CONSTANT
SIMM: NO SIMS: NO_ALARM SIOL:CONSTANT SPVT:
0xc135e0
STAT: NO_ALARM TIME: 2017-04-11 20:53:12.153366126 TPRO: 0
TSE: 0 TSEL:CONSTANT UDF: 0 VAL: (nil)
ASP: (nil) BKPT: 00 BPTR: 0xbcd3a0 BUSY: 0
NO_ALARM
DISV: 1 DPVT: 0xc05be0 DSET: 0x7f2dbdcea9a0
INP:INST_IO @asyn(testAPD,1,1)OSC_WAVEFORM LCNT: 0
LOPR: 0 LSET: 0xc07f60
MLOK: 70 d3 bc 00 00 00 00 00 MPST: Always
NAME: PIEZO:OSC-CH1-WAVEFORM NELM: 1000 NORD: 1000
SIML:CONSTANT
0xc138f0
STAT: NO_ALARM TIME: 2017-04-11 20:53:29.910249080 TPRO: 0
ASP: (nil) BKPT: 00 BPTR: 0xbcf360 BUSY: 0
NO_ALARM
DISV: 1 DPVT: 0xc060e0 DSET: 0x7f2dbdcea9a0
INP:INST_IO @asyn(testAPD,2,1)OSC_WAVEFORM LCNT: 0
LOPR: 0 LSET: 0xc07f80
MLOK: 30 f3 bc 00 00 00 00 00 MPST: Always
NAME: PIEZO:OSC-CH2-WAVEFORM NELM: 1000 NORD: 1000
SIML:CONSTANT
0xc13c00
STAT: NO_ALARM TIME: 2017-04-11 20:54:17.907769453 TPRO: 0
ASP: (nil) BKPT: 00 BPTR: 0xa7b540 BUSY: 0
NO_ALARM
DISV: 1 DPVT: 0xab0810 DSET: 0x7efec944b9a0
INP:INST_IO @asyn(testAPD,3,1)OSC_WAVEFORM LCNT: 0
LOPR: 0 LSET: 0xab21d0
MLOK: 10 b5 a7 00 00 00 00 00 MPST: Always
NAME: PIEZO:OSC-CH3-WAVEFORM NELM: 1000 NORD: 1000
RDES: 0xa30650 RPRO: 0 RSET: 0x7efec91d4340
SIML:CONSTANT
0xabe140
STAT: NO_ALARM TIME: 2017-04-11 20:52:33.970326348 TPRO: 0
Best regards,
Paweł
W dniu 2017-04-11 18:24, Mark Rivers napisał(a):
Hi Pawel,
What is the SCAN field of your waveform record? I suspect it is
probably periodic ("1 second", etc.). For this application you should
set it to SCAN="I/O Intr". Then the waveform record will process each
time your driver does a callback to device support. If the record is
periodically processing at 1 second and your driver is doing callbacks
faster than 1 Hz then you will see the error you report.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Pawel Plewinski
Sent: Tuesday, April 11, 2017 8:49 AM
To: [email protected]
Subject: [AsynPortDriver] "Multiple interrupt callbacks between
processing" warning with multiple arrays
I've recently written asyn-based device support for a custom device
communicating over PCIe. One of its functions is to periodically
retrieve 4 waveforms from 4 channels, which is done in a separate
thread, from which the callback function is called to notify asyn about
change. I heavily based the code on the AsynPortDriver example.
The driver works, however if the update rate is lower than 1 second,
strange warning appears in the console at the time of every refresh
(and
that's only for one of 4 channels), namely:
2017/04/11 15:42:08.682 PIEZO:OSC-CH0-WAVEFORM
devAsynFloat64Array::interruptCallbackInput
\000\000\000\000\000@\205?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?\000\000\000\000\000\000\204?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?\000\000\000\000\000@\205?\000\000\000\000\000\000\204?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?
devAsynFloat64Array::processCommon, warning, multiple interrupt
callbacks between processing
The parameters passed to the top level constructor are
: asynPortDriver(portName,
4, /* maxAddr */
(int)NUM_SCOPE_PARAMS,
asynInt32Mask | asynFloat64Mask |
asynFloat64ArrayMask | asynEnumMask | asynDrvUserMask, /* Interface
mask
asynFloat64ArrayMask | asynEnumMask, /* Interrupt mask */
ASYN_MULTIDEVICE, /* asynFlags. This driver does
not block and it is not multi-device, so flag is 0 */
1, /* Autoconnect */
0, /* Default priority */
0) /* Default stack size*/
The readback thread code:
void piezoPortDriver::readbackTask(void)
while (1) {
bool stopped = false;
lock();
auto new_data = osc->fetch_data(vtim, vdat);
unlock();
if (!stopped)
lock();
this->osc_update_trigger();
unlock();
callParamCallbacks();
for (int i = 0; i < 4; i++){
doCallbacksFloat64Array(vdat[i].data(), vdat[i].size(),
P_OscWaveform, i);
usleep(100000);
The fetch_data method reads four 1000-element double vectors from PCIe.
Could you give me some suggestions what may be wrong?
Paweł Plewiński
Department of Microelectronics and Computer Science
Lodz University of Technology
- RE: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Mark Rivers
- [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Paweł Plewiński
RE: sumitomo f70 compressor Linda.Pratt
Re: sumitomo f70 compressor Lionberger, Carl A.
<2017>
<2017>
