1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: partial (damaged?) UDP msg
From: "Williams Jr., Ernest L." <[email protected]>
To: Zhang Yuliang <[email protected]>, tech-talk <[email protected]>
Date: Sat, 15 Apr 2017 15:20:48 +0000
Please provide more information:
Such as what version of EPICS are you running for your CA server and clients?
Cheers,
Ernest
From: [email protected] [[email protected]] on behalf of Zhang Yuliang [[email protected]]
Sent: Saturday, April 15, 2017 4:27 AM
To: tech-talk
Subject: CAS: partial (damaged?) UDP msg
Hi all,
I found that one soft ioc output the following information:
epics> CAS: partial (damaged?) UDP msg of 8 bytes from 10.1.204.140:54439 ?
CAS: request from 10.1.204.140:54439 => CAS: Missaligned protocol rejected
CAS: Request from 10.1.204.140:54439 => cmmd=0 cid=0x4143435f type=0 count=3100 postsize=3100
CAS: Request from 10.1.204.140:54439 =>   available=0x4c524254  N=3 paddr=(nil)
CAS: invalid (damaged?) UDP request from 10.1.204.140:54439 ?
At that time, all of our Labview and C# type CA servers hung up(the standard iocs were all ok), no response to the ca search from clients. After we reboot the ca servers, it return to OK.
It is the first time we saw this and I think the ca server hung up event has relation to the invalid request.
Zhang Yuliang
Re: RE: partial (damaged?) UDP msg Zhang Yuliang
CAS: partial (damaged?) UDP msg Zhang Yuliang
Prev: CAS: partial (damaged?) UDP msg Zhang Yuliang
Next: Re: Archiver Appliance established multiple CA connections for one channel Shankar, Murali
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: Re: RE: partial (damaged?) UDP msg Zhang Yuliang
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
