1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: RE: partial (damaged?) UDP msg
To: "Williams Jr., Ernest L." <[email protected]>
Date: Sun, 16 Apr 2017 09:12:51 +0800 (GMT+08:00)
Hi Ernest,
The EPICS base used for running softIOC is 3.14.12.5.
The C# type CA servers are using CaSharpServer module and the Labview type CA servers are using the NI DSC module.
Another thing I forgot to mention yestoday, all the C# type CA servers did not lost the 'exist eatablished TCP connection with clients', but they could not response to any new CA search requests(by caget or CSS), while the Labview type CA servers lost TCP connections. All the hung up CA servers did not output any error messages.
Yuliang
> -----原始邮件-----
> 发件人: "Williams Jr., Ernest L." <[email protected]>
> 发送时间: 2017年4月15日 星期六
> 收件人: "Zhang Yuliang" <[email protected]>, tech-talk <[email protected]>
> 抄送:
> 主题: RE: partial (damaged?) UDP msg
> Hi,
> Please provide more information:
> Such as what version of EPICS are you running for your CA server and clients?
> Cheers,
> Ernest
> From: [email protected] [[email protected]] on behalf of Zhang Yuliang [[email protected]]
> Sent: Saturday, April 15, 2017 4:27 AM
> To: tech-talk
> Subject: CAS: partial (damaged?) UDP msg
> Hi all,
> I found that one soft ioc output the following information:
> epics> CAS: partial (damaged?) UDP msg of 8 bytes from 10.1.204.140:54439 ?
> CAS: request from 10.1.204.140:54439 => CAS: Missaligned protocol rejected
> CAS: Request from 10.1.204.140:54439 => cmmd=0 cid=0x4143435f type=0 count=3100 postsize=3100
> CAS: Request from 10.1.204.140:54439 =>   available=0x4c524254  N=3 paddr=(nil)
> CAS: invalid (damaged?) UDP request from 10.1.204.140:54439 ?
> At that time, all of our Labview and C# type CA servers hung up(the standard iocs were all ok), no response to the ca search from clients. After we reboot the ca servers, it return to OK.
> It is the first time we saw this and I think the ca server hung up event has relation to the invalid request.
> Regards,
> Zhang Yuliang
CAS: partial (damaged?) UDP msg Zhang Yuliang
RE: partial (damaged?) UDP msg Williams Jr., Ernest L.
Prev: Re: Archiver Appliance established multiple CA connections for one channel Shankar, Murali
Next: Re: CAS: partial (damaged?) UDP msg Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: partial (damaged?) UDP msg Williams Jr., Ernest L.
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
