Subject: RE: EPICS PV for data in Area Detector
To: Iain Marcuson <[email protected]>, "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Thu, 4 May 2017 01:51:34 +0000
Hi Iain,
Some questions:
> I note there are no NDArrayCallbacks.
Please explain exactly what you mean by that statement.  What are you observing?
- Is your driver calling doCallbacksGenericPointer()?
- Are ArrayCallbacks enabled in your driver?
- Is the NDPluginStdArrays plugin enabled (EnableCallbacks)?  Is it configured to get its data from your driver?  Are the TimeStamp_RBV and UniqueId_RBV records in NDPluginStdArrays updating?
> When I look at $(P)$(R)ArrayData, it appears to be all zeroes except the first value
How are you looking at $(P)$(R)ArrayData, i.e. with what tool?
From: [email protected] [[email protected]] on behalf of Iain Marcuson [[email protected]]
Sent: Wednesday, May 03, 2017 3:43 PM
To: [email protected] >> EPICS Tech Talk
Subject: EPICS PV for data in Area Detector
I am trying to transfer pixel values from an Area Detector driver's private variable into an NDArray for viewing with ImageJ.  I have verified that the ImageJ plugin works.  I have also verified that the test data are generated correctly.  My code follows that of the Mythen driver, except with two dimensions instead of one.  I alloc() an NDArray and copy the pixel values over.  I have verified that the pixel values are transferred correctly to the pImage.  I note there are no NDArrayCallbacks.  When I look at $(P)$(R)ArrayData, it appears to be all zeroes except the first value, which appears to increment on both acquisition and "caget $(P)$(R)ArrayData".  What might I be missing?
Thank you,
Iain.
RE: EPICS PV for data in Area Detector Iain Marcuson
Prev: EPICS PV for data in Area Detector Iain Marcuson
Next: Question about build StreamDevice application lzf neu
Next: RE: EPICS PV for data in Area Detector Iain Marcuson
