Subject: Question about build StreamDevice application
Date: Thu, 4 May 2017 03:04:53 +0000
hi,
In order to build an StreamDevice application,
I use the following commands to build softioc:
makeBaseApp.pl -t example top
makeBaseApp.pl -i -t example top
make
and add the following lines to /top/topApp/src/makefile:
top_LIBS += stream
top_LIBS += asyn
top_DBD += asyn.dbd
top_DBD += stream.dbd
according to the streamDevice manual page 3, the following three lines should be included in my xxxAppInclude.dbd:
registrar(drvAsynIPPortRegisterCommands)
registrar(drvAsynSerialPortRegisterCommands)
registrar(vxi11RegisterCommands)
It seems in my case I should find topInclude.dbd file to add the above three lines.
My problem is
toplnclude.dbd does not exist before execute "make" command in the top directory of my softioc and "make clean" command can delete it from /top/topApp/src/O.Common folder.
I have no idea do I miss somthing or anyother method to cope with my problem.
Any help will be appreciated and thanks in advance !
Zhefu
RE: Question about build StreamDevice application Mark Rivers
Prev: RE: EPICS PV for data in Area Detector Mark Rivers
Next: RE: EPICS PV for data in Area Detector Iain Marcuson
Prev: RE: EPICS PV for data in Area Detector Iain Marcuson
Next: RE: Question about build StreamDevice application Mark Rivers
