Subject: Streamdevice waveform - binary data stream with no separator
To: EPICS tech talk <[email protected]>
Date: Thu, 18 May 2017 17:25:07 +0000
Good morning to all!
I have an equipment that sends 140 16-bit words in sequence. I want to put the 140 numbers in a waveform using Streamdevice.
The manual says:
Separator = "";
String. Affects out and in commands.
When formatting or parsing array values in a format converter (see formats and waveform record), what string to write or to expect between values?
and gives this protocol example:
array_out {separator=", "; out "an array: (%.2f)";}
How can I address my case using something like the separator idea, when I don't have a separator, but a fixed byte size for each number?
Thank you for all help!
Márcio Paduan Donadio
Software Engineer - TID-AIR-ACS - SLAC
Prev: Troubleshooting the redirection-to-records feature of streamDevice Kevin Peterson
Next: Micronix MMC-10 Kevin Peterson
Next: Re: Streamdevice waveform - binary data stream with no separator Paduan Donadio, Marcio
