Subject: Re: Streamdevice waveform - binary data stream with no separator
Date: Thu, 18 May 2017 19:33:12 +0000
Thank you, Iain.
How do you let stream device know that you want exactly 140 numbers? Only setting NELM is sufficient?
Best regards,
Márcio Paduan Donadio
Software Engineer - TID-AIR-ACS - SLAC
De: Iain Marcuson <[email protected]>
Enviado: quinta-feira, 18 de maio de 2017 12:19
Para: Paduan Donadio, Marcio
Assunto: RE: Streamdevice waveform - binary data stream with no separator
I have used something similar.  You would use the %r format specifier, in I believe something like:
In “%2.2r”
You may need to add the “#” flag to account for endianness.  For this you would set the separator to be blank.
Iain.
From: [email protected] [mailto:[email protected]] On Behalf Of Paduan Donadio, Marcio
Sent: Thursday, May 18, 2017 1:25 PM
To: EPICS tech talk <[email protected]>
Subject: Streamdevice waveform - binary data stream with no separator
Good morning to all!
I have an equipment that sends 140 16-bit words in sequence. I want to put the 140 numbers in a waveform using Streamdevice.
The manual says:
Separator = "";
String. Affects out and in commands.
When formatting or parsing array values in a format converter (see formats and waveform record), what string to write or to expect between values?
and gives this protocol example:
array_out {separator=", "; out "an array: (%.2f)";}
How can I address my case using something like the separator idea, when I don't have a separator, but a fixed byte size for each number?
Thank you for all help!
Re: Streamdevice waveform - binary data stream with no separator Zimoch Dirk (PSI)
Streamdevice waveform - binary data stream with no separator Paduan Donadio, Marcio
Prev: Micronix MMC-10 Kevin Peterson
Next: RE: EDM questions Zelazny, Michael Stanley
Prev: Streamdevice waveform - binary data stream with no separator Paduan Donadio, Marcio
Next: Re: Streamdevice waveform - binary data stream with no separator Zimoch Dirk (PSI)
