Subject: EDM X-Y Graph lot widget oddities
To: EPICS mailing list <[email protected]>, "Sinclair, John William" <[email protected]>
Date: Mon, 5 Jun 2017 12:49:39 -0700
The EDM X-Y Graph widget (1-12-103, but these issues seem to be present in lots of versions) exhibits some unexpected (by me, anyway) behaviour.
Here’s the record holding the data:
record(waveform, "$(P)$(R)AWG3:pattern") {
    field(DESC, "AWG 3 pattern")
    field(DTYP, "asynInt16ArrayOut")
    field(INP,  "@asyn($(PORT) 3 0)")
    field(FTVL, "SHORT")
    field(NELM, "1400")
And here’s the widget configuration.  I’ve tried all sorts of combinations of settings (scope/plot, plot-n-and-stop/plot-last-n specify the record as the trigger records, etc.) but the problems appear the same.
# (X-Y Graph)
object xyGraphClass
beginObjectProperties
major 4
minor 8
release 0
# Geometry
x 2
y 26
w 745
h 365
# Appearance
border
plotAreaBorder
autoScaleBothDirections
graphTitle "DAC $(CHAN) AWG Pattern"
xLabel "Sample (ms)"
yLabel "DAC"
fgColor index 14
bgColor index 3
gridColor index 14
font "helvetica-medium-r-14.0"
# Operating Modes
nPts 2
# X axis properties
showXAxis
xAxisSrc "AutoScale"
xMin 0
xMax 1
xShowLabelGrid
# Y axis properties
showYAxis
yAxisSrc "AutoScale"
yMax 1
yShowLabelGrid
# Y2 axis properties
y2AxisSrc "AutoScale"
y2Max 1
# Trace Properties
numTraces 1
yPv {
  0 "$(P)$(R)AWG$(CHAN):pattern"
nPv {
  0 "$(P)$(R)AWG$(CHAN):pattern.NORD"
lineThickness {
  0 2
plotUpdateMode {
  0 "xOrY"
opMode {
  0 "plot"
ySigned {
  0 1
plotColor {
  0 index 20
Issue 1 — Autoscaling
An example plot with NORD=1000 looks as shown below.  I find it odd that the autoscaling has decided to start the X-axis at -200 rather than 0 and to end it at 1200 rather than 1000.  And why make the Y axis extend below 0?
Issue 2 — Plotting stale data
A client has written 100 points to the waveform record.  The EDM screen shows:
The client then writes 1000 points to the waveform record — the same shape, but 10 times as many points.  The EDM screen shows:
The widget has correctly determined the correct number of points, but appears to have taken Y values from the record before the client has filled the last 900 or so points.
Closing the EDM window and reopening it shows the correct result:
Prev: Re: EPICS Base-3.16.1 Released Johnson, Andrew N.
Next: Re: asyn timeout Paduan Donadio, Marcio
Prev: Re: stream enum Dirk Zimoch
Next: epicsQt release 3.4.3 - at GitHub Andrew C. Starritt
