Subject: Re: stream enum
To: <[email protected]>
Date: Thu, 8 Jun 2017 12:48:46 +0200
Your conversion "\x02%*4s%c%*c%*c%*c%*c%*c%*c%*c%*c%*c%*s" lets me assume you want to read the character number 6 (after an initial 0x02 and a 4 byte string) as a number. But %c gives not a number but a string. To read one char as a number use %1d and a longin record.
in "\x02%*4s%1d%*c%*c%*c%*c%*c%*c%*c%*c%*c%*s";
Be aware that %*4s reads less than 4 chars if it finds a space or tab! Maybe that is not what you want. Try %*4c instead:
in "\x02%*4c%1d%*c%*c%*c%*c%*c%*c%*c%*c%*c%*s";
Dirk
On 05.06.2017 15:28, l123173 wrote:
Hi all,
   I met some little question about stream.
   After I sent command, I received a sequence of character through stream.
   The pv type was stringin and the value of the pv was 1(string) or
0(string).
   My question was that, I need the pv value was natural number( 0 or 1
), not string type.
   I have tried to change the stringin to ai, some error came out. Then
I think I could use the enum, but I could not know the usage though I tried.
   Could someone give some help.
Li xing
My db and proto file.
record(stringin, "$(P)$(R)STAT")
    field(DESC, "test")
    field(DTYP, "stream")
    field(INP,  "@devplc2.proto STAT $(PORT) $(A)")
STAT{
    out "\x0500FFBR2Y0000402F";
     in "\x02%*4s%c%*c%*c%*c%*c%*c%*c%*c%*c%*c%*s";
stream enum l123173
Prev: RE: makeBaseApp.pl Compilation error on Windows x64 freddie.akeroyd
Next: Re: makeBaseApp.pl Compilation error on Windows x64 Saeed Haghtalab
Prev: RE: stream enum Mark Rivers
Next: EDM X-Y Graph lot widget oddities Eric Norum
