Subject: RE: Area Detector and high performance NVME devices
To: "Engbretson, Mark S." <[email protected]>
Date: Fri, 30 Jun 2017 12:44:07 +0000
Hi Mark,
> What i want is an effect more like just opening 2 or more distinct files at once. If they are doing totally different things,
> with totally unrelated life cycles, what is the mutex protecting?
In general the mutex is protecting global structures and variables in the HDF5 library.  Consider an extremely simple example pseudocode:
FILE *globalFileId;
mutex globalLock;
void writeChunk(FILE *fileId, void *pData)
  lock(globalLock);
  globalFileId = fileId;
  writeData(pData);
  unlock(globalLock);
static void writeData(void *pData)
  fwrite(pData, 1, 1000, globalFileId);
writeChunk is externally visible and called by user-code, while writeData is private and hidden.  Because writeChunk does not pass fileId directly to writeData, but rather uses a global variable, it needs to be protected by a mutex.  Otherwise this code would not be thread safe.
Obviously the HDF5 library does not do anything this silly, but the principle is the same.  It uses global variables and structures that need to be protected by a mutex.  It does this in such a way that only 1 user-callable HDF5 function can be running at once, i.e. there is no concurrency possible in the library.   The only way to achieve concurrency is to run multiple processes, not multiple threads.  The HDF5 documents are very clear about this, and the performance results I posted yesterday using multiple threads vs multiple processes confirm it.
Sent: Thursday, June 29, 2017 7:08 PM
To: Mark Rivers
Cc: [email protected]; [email protected]
Subject: Re: Area Detector and high performance NVME devices
But wait . . . It can not work that way. Threads pop in and out of existence all the time. They may or may not use the HDF5 libraries, but if they do, they certainly would not want to have a dependency on code or constructs that could go "poof" at any instant.
What i want is an effect more like just opening 2 or more distinct files at once. If they are doing totally different things, with totally unrelated life cycles, what is the mutex protecting?
On Jun 29, 2017, at 18:16, Mark Rivers <[email protected]> wrote:
What you propose would not work, because the problem is not in NDFileHDF5.cpp, it is in the underlying HDF5 library.  There are global structures there that you would not be making multiple instances of, so they need to be protected by the mutex.
-----Original Message-----
From: Mark S. Engbretson [mailto:[email protected]]
Sent: Thursday, June 29, 2017 5:05 PM
To: [email protected]; Mark Rivers
For the sake of argument, what would happen if instead of creating multiple
instances of the HDF File plugin, which is actually the exact same entity, I
instead cloned the NDFileHDF5.cpp sources and made it a couple of unique
plugins named <NDFileHDF5>_A,B,C,and D. I can do this on windows system and
force every thread to have its own unique copy everything, so there is no
conflicts in non thread safe code just as you would not expect any mutex
issues from another process running on the system.
I know that I should technically be able to use constructs such as
void *handle1 = dlmopen(LM_ID_NEWLM, "/path/to/library.so", RTLD_NOW);
void *handle2 = dlmopen(LM_ID_NEWLM, "/path/to/library.so", RTLD_NOW);
Where the references is to the same shared library, but via difference
handles don't conflict.  But there should be easier ways to achieve the same
effect. I.e, with multiple file plugins, there are no common anythings that
should need that mutex lock or could be trashed.
Sent: Thursday, June 29, 2017 9:34 AM
To: [email protected]; [email protected]
Area Detector and high performance NVME devices Mark S. Engbretson
RE: Area Detector and high performance NVME devices Mark Rivers
RE: Area Detector and high performance NVME devices Mark S. Engbretson
Re: Area Detector and high performance NVME devices ulrik.pedersen
RE: Area Detector and high performance NVME devices ulrik.pedersen
Re: Area Detector and high performance NVME devices Engbretson, Mark S.
Prev: RE: Area Detector and high performance NVME devices ulrik.pedersen
Next: areaDetector ADViewers R1-0 released Mark Rivers
Next: PVs disconnected in CSS BOY despite access through caget Iain Marcuson
