Subject: Re: How to compile only for a target architecture
To: Kevin Peterson <[email protected]>
Cc: [email protected]
Date: Wed, 12 Jul 2017 23:39:01 +0200
Thanks for your quick reply, Kevin.
However what I´m looking for is to compile only for a target_architecture and not for the host. For example Host: x86_64 Target: Linux-arm. I just want to compile for linux-arm from my x86 host.
Regards, Ricardo
El 2017-07-12 23:32, Kevin Peterson escribió:
Ricardo,
If you leave CROSS_COMPILER_TARGET_ARCHS empty in the
configure/CONFIG_SITE of the module you're building, it should only
build for the host arch:
  CROSS_COMPILER_TARGET_ARCHS =
Kevin
On 07/12/2017 04:24 PM, Ricardo Herrero wrote:
Hello,
 I want to ask you how to compile only for one target architecture in
EPICS. In the application developer´s guide it is not clear enough . It seems as it always compile for host and for other target architectures.
I want to compile for one target architecture, but not all of them and
not for the host architecture. I just need to compile for linux-arm in
any case from a x86_64.  How can I do that?
Thanks for your help, in case you need it I can send you the Makefiles I
´m working on.
Ricardo
Doctorando i2a2
Jefe de Area de Ingeniería de Sistemas - CEH- CEDEX
Re: How to compile only for a target architecture Ronald L. Sluiter
How to compile only for a target architecture Ricardo Herrero
Re: How to compile only for a target architecture Kevin Peterson
Prev: Re: How to compile only for a target architecture Kevin Peterson
Next: Re: How to compile only for a target architecture Andrew Johnson
Next: Re: How to compile only for a target architecture Ronald L. Sluiter
