Subject: Re: How to compile only for a target architecture
To: Ricardo Herrero <[email protected]>
Cc: [email protected]
Date: Wed, 12 Jul 2017 16:44:03 -0500
In the past you had to build the EPICS_HOST_ARCH because there were host tools built at the beginning that were needed later on in the build. I don't know if that is still the case with the more recent version of EPICS base.
What EPICS base version are you trying to build without the host architecture?
Ron
On 07/12/2017 04:39 PM, Ricardo Herrero wrote:
Thanks for your quick reply, Kevin.
However what I´m looking for is to compile only for a target_architecture and not for the host. For example Host: x86_64 Target: Linux-arm. I just want to compile for linux-arm from my x86 host.
Regards, Ricardo
El 2017-07-12 23:32, Kevin Peterson escribió:
Ricardo,
If you leave CROSS_COMPILER_TARGET_ARCHS empty in the
configure/CONFIG_SITE of the module you're building, it should only
build for the host arch:
  CROSS_COMPILER_TARGET_ARCHS =
Kevin
On 07/12/2017 04:24 PM, Ricardo Herrero wrote:
Hello,
 I want to ask you how to compile only for one target architecture in
EPICS. In the application developer´s guide it is not clear enough . It
seems as it always compile for host and for other target architectures.
I want to compile for one target architecture, but not all of them and
not for the host architecture. I just need to compile for linux-arm in
any case from a x86_64.  How can I do that?
Thanks for your help, in case you need it I can send you the Makefiles I
´m working on.
Ricardo
Re: How to compile only for a target architecture Andrew Johnson
How to compile only for a target architecture Ricardo Herrero
Re: How to compile only for a target architecture Kevin Peterson
Re: How to compile only for a target architecture Ricardo Herrero
Prev: Re: How to compile only for a target architecture Andrew Johnson
Next: Re: How to compile only for a target architecture Ricardo Herrero
Prev: Re: How to compile only for a target architecture Ricardo Herrero
Next: Re: How to compile only for a target architecture Andrew Johnson
