Subject: QtQuick + EPICS PV = CSDataQuick
To: Epics <[email protected]>
Cc: Sebastian Steinlechner <[email protected]>
Date: Fri, 15 Sep 2017 18:27:07 +0000
Hi all,
QML/QtQuick has made easy the creation of fluid, dynamic GUI programs through a declarative syntax.
I started to experiment the EPICS integration since its introduction and intermittently made improvements
as the technology develops.
The result is a qml module CSDataQuick [1], consisting of two submodules:
  * CSDataQuick.Data: the CSData object and the data engine plugin system.
  * CSDataQuick.Components: the standard visual items.
Built upon that is a ADLViewer to display ADL/QML files, and a builder to build throwaway GUIs on-the-fly.
Check out the documents [2] to get started. For the impatient, there is ready-to-use Anaconda binary packages.
	$ conda install -c paulscherrerinstitute csdataquick
See more about that in the installation section.
This module is of beta quality. Feel free to reports problems and start discussions in the issue tracker.[3]
Best
Xiaoqiang
[1] https://github.com/xiaoqiangwang/CSDataQuick
[2] https://xiaoqiangwang.github.io/CSDataQuick-doc
[3] https://github.com/xiaoqiangwang/CSDataQuick/issues
Prev: Modbus R2-10 available Mark Rivers
Next: acctst failure Al Honey
